Ski-Doo clutch removal - HCS Snowmobile Forums
General Snowmobile Forum This is a serious discussion forum and a 100% NO BASHING ZONE. This area is here for members who are looking for serious answers for serious questions or discussion and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website Without Warning.The calling out or posting of another members user name in the title of a thread a members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently.
Old 11-02-2006, 07:25 PM   #1 (permalink)
Newbie
Does anybody have any experience removing Ski-doo clutches? I pulled the main clutch off my 99 ski-doo f3, then took a puller to the fixed disc on the drive clutch. Ouch! Now it's in pieces. The shop manual seems
to show the shaft attached to it, so I assume the shaft has to come off. The transmission is on the motor, and the motor is still on the sled. I just need to replace the ring gear. Any help is appreciated, as would be a used fixed disc!
THX
Tom
tganley1 is offline   Reply With Quote
Old 11-02-2006, 07:30 PM   #2 (permalink)
dasledhed's Avatar
I dont understand. You pulled the primary clutch off and split it? Transmission?
dasledhed is offline   Reply With Quote
Old 11-03-2006, 01:11 PM   #3 (permalink)
what are you trying to do?
skidoo TRA drive clutches come off with a puller tool (like all drive clutches).
once you remove the drive clutch spring, the clutch will come apart.
'06 Skidoo GTX 500ss
'83 Skidoo Blizzard 9700
'82 Skidoo Blizzard 9500
'81 Skidoo Blizzard 9500
'80 Motoski Supersonic
(2) '77 Yamaha SRX 440's
'75 Yamaha GPX 433
'77 Arctic Kitty Cat
'71 Arctic Panther 399
'71 Arctic Puma 399
snoeproe is offline   Reply With Quote
Old 11-03-2006, 01:25 PM   #4 (permalink)
FIREBALL 440's Avatar
Current Sled(s): 2003 Renegade
14-15 Mileage: 1420
13-14 Mileage: 1250
...and welcome to HCS.
"...and I was like braap braap almost hit a fuckin tree, like fuckin braaap brap brap braaaaaaap..."
FIREBALL 440 is offline   Reply With Quote
Old 11-03-2006, 01:53 PM   #5 (permalink)
bt260's Avatar
Sounds like he only removed the moveable sheave of the clutch and then used an ordinary gear puller on the fixed sheave, a mistake that will cost a couple hundred bucks to fix. The problem now is removing the rest of the sheave from the PTO ond of the crank, not fun with no puller threads. Probably the easiest way is to cut through it with a die grinder, taking great caution not to damage the crank itself. Good luck with that one.
bt260 is offline   Reply With Quote
Old 11-03-2006, 06:31 PM   #6 (permalink)
dasledhed's Avatar
Ohh.....i couldnt make any sense out of that post.Yea,thats not good.
Old 11-03-2006, 11:25 PM   #7 (permalink)
Newbie
Hey Folks,
thanx for responding. Yeah, got the sprint off, then the outer portion of the clutch.
The fixed disc was still on the crank. I was trying to remove it to add a ring gear for a new electric start.
It doesn't seem like brain surgery, as there are a dozen of them on EBAY, but all the discs seem to have the shaft attached. Doesn't sem to be the crank, seems to be a split shaft, that comes off right behind the fixed disc.
ALL ON EBAY SEEM TO HAVE THE SHAFT ATTACHED.
Old 11-03-2006, 11:28 PM   #8 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
13-14 Mileage: 1,864
Riding Since: 1959
Discs? You must mean "sheaves"
Old 11-04-2006, 11:17 AM   #9 (permalink)
get yourself a clutch puller tool for the TRA. this is easy with the correct tool
'75 Yamaha GPX 433
'71 Arctic Puma 399
Old 11-04-2006, 09:32 PM   #10 (permalink)
dasledhed's Avatar
The sheave that is on the crank does have the shaft with the spline attached if thats what your asking.You have to buy a clutch puller and the whole thing will come off,its on a taper.
