Governor bypass...Yes or no????? - HCS Snowmobile Forums
Old 11-15-2010, 01:25 PM   #1 (permalink)
Member
Default Governor bypass...Yes or no?????
Looking for real world experience with this mod for the 120 minis. Want to make my sons 120 Assault faster for him this winter but don't want to grenade the engine in the process. Tried searching but still not sure. Any input appreciated. Also, how hard to take out the plastic govenor gear. Does the engine have to come out?
Thanks
ken
NF600SHIFT is offline   Reply With Quote
Old 11-17-2010, 09:52 AM   #2 (permalink)
tntfaguy's Avatar
Ken, I can only speak to experience with the Arctic Cat 120, but yes it makes a big difference and yes you have to take the motor out. Fairly easy to do though. For some reason I don't really hear of people taking them out of the Polaris or Ski-Doo mini's only the Cat's....not sure if there's a reason....
tntfaguy is offline   Reply With Quote
Old 11-26-2010, 12:41 PM   #3 (permalink)
OutKast's Avatar
Current Sled(s): 2017 SBA 800 2-INDY 800s 2015 INDY 550
Previous Sled(s): Couple D8's
16-17 Mileage: 1400
On my Son's Polaris 2010 120 it is just a $7.00 spring. And no the engine does not have to come out. It would do 9mph before the mod and now does 15. I rode beside him before and after and verified this. It is a noticable difference but not extreme. I will be looking to get more speed for him after a few more rides and will be changing the Gear and Hub. I believe, but could be wrong, that this will get the little bugger to 28 mph.
His Mommy wont like this haaa
2006 AMCRA Amateur Rookie of The Year
2007 AMCRA Amateur Open Sportbike Champion
OutKast is offline   Reply With Quote
Old 11-26-2010, 01:26 PM   #4 (permalink)
SayByeBye's Avatar
Current Sled(s): CFR 1K, 07F6, Z120/200 mod
Previous Sled(s): Hijacked Z1 Turbo
Favorite Riding Area: On Snow
Riding Since: 3
If you change the spring or zip tie it you will override the governer. The problem is that with the increased rpms the plastic governer gear can come apart sending parts through your engine, destroying it.
To remove this the engine needs to come out and the governer assembly needs to be removed. Arctic cat and ski doo for sure.. and I think polaris too.
I ran mine for a season with the spring zip tied without a failure then removed it season two. Its an easy job but time consuming. when you see how its made youll be glad its out.
Now the 120 is out and a 200 is in its place (pulled the governer out of it too) Should have the install finished tonight.
SayByeBye is offline   Reply With Quote
Old 11-27-2010, 08:08 PM   #5 (permalink)
Member
Current Sled(s): 2009 Switchback 600
It sure seems like they made it needlessly complex. A simple throttle stop would have acclomplished the same thing, right?
What exactly does the gear do?
I went to do the bypass thing with the plastic tie on the zr120, but it appears that when the throttle is pinned to the handlebar, the carb is wide open. In other words, it doesn't look like wiring the gov spring will do anything. Am I missing something?
mt99 is offline   Reply With Quote
Old 11-30-2010, 03:38 PM   #6 (permalink)
SayByeBye's Avatar
Riding Since: 3
A throttle stop wouldn't give you the same low end or hill climbing/deep snow power; when you apply the throttle the carb will fully open allowing more air and fuel for more power to get you going, once the engine reaches 3600 +/- rpm the weights in the gov expand closing the throttle allowing only enough flow to rev 3600 rpm. when climbing a hill the load will bog the motor so when the rpms drop the gov releases tension and you get more throttle.
A throttle stop limits throttle position but not revs ie: if limited to half throttle you wouldn't have the power to climb a hill, but going down the hill you'd over-rev.
Old 11-30-2010, 08:03 PM   #7 (permalink)
Member
Thanks for the explanation. So can I infer from your explanation that wiring the spring will increase the top speed even though it doesn't change the position of the throttle blade in the carb?
Old 12-03-2010, 11:01 AM   #8 (permalink)
SayByeBye's Avatar
Riding Since: 3
Right. even with the spring tied the throttle still has full movement but with little or no interference from the governor.
Tying the spring will limit the governor's interference. You can start by installing the zip tie loose and gradually tightening it until you have the speed your after. Chances are you'll have it tight in no time getting max revs.... that's when the plastic gear is at risk of coming apart.
Old 12-04-2010, 03:07 AM   #9 (permalink)
kraven's Avatar
Current Sled(s): 2007 DRAGON 700, 4500 MILES
Previous Sled(s): 2002 EDGE-X 800,6400 miles, 1999 XCR 800
Favorite Riding Area: YELLOWSTONE
Riding Since: 1985
Cool Polaris 120 governor by-pass
Thanks
ken
On a 2008 POLARIS 120, note the RED mini-tie holding the spring in the "collapsed" position, been runnin' it for (2) seasons like this.
In a perfect world, the plastic governor gear should be removed, engine removal is req'd
Name:	120 GOVERNOR SPRING.jpg
Byron Circa 1984, '72 Dodge Colt, Full Tube Chassis, Strange Struts, 4 Link, Koni Coil Overs, 15" x 33", Mild 426 Wedge, Torqueflite, Lexan windows, Dzus Fasteners & Quick Release Pins Everywhere, All Polished Aluminum Interior, Fuel Cell, "Weld" Superlite Wheels, 2220 lbs. w/Driver, Leaving the Starting Line Carrying the Front Wheels and Being Plastered into the Back of the Seat and Stopping it from 137+ m.p.h. by Pulling the Parachute-PRICELESS!!!
Byron, 1982, 71 Dodge Demon, 426 Wedge, Aluminum 4-speed, Narrowed Dana 4.56, Alston Bars & Floater, SS Springs, 12.20" x 31.25" Firestones, Polished Centerlines, 10 pt Rollcage, Aluminum wheel tubs, Fiberglass fenders, hood, & decklid
1986 INDY 600 LIMITED EDITION CHROME PACKAGE [/b]91 M.P.H. @ RADAR RUNS 1000' (6000+ MILES) TRAILERED TO YELLOWSTONE IN 1988
kraven is offline   Reply With Quote
Old 12-14-2010, 12:37 PM   #10 (permalink)
Member
If the plastic gear is removed will the motor over rev. Or how do you keep it from over reving
WERESTHESNOW is offline   Reply With Quote
