200 cc is now in and running. - HCS Snowmobile Forums
Old 02-25-2009, 08:43 AM   #1 (permalink)
It's a Honda clone 200cc 6.5hp- govener gear removed, 18lbs valve springs, custom pipe with baffle, Mikuni 22mm round slide carb, 10 tooth Sporttec clutch x 36 tooth rear.
It seems to run good, but I realize the carb is not jetted properly to allow maxium performance. Does anyone have an idea of what jets and needle setting for this set-up? It would be nice to be pointed in the right direction to save several hours of testing.
Also I have a 26 tooth rear sprocket to test, will it have the balls to turn it?
Thanks in advance.
Dave
1969 Ski Doo Nordic 371
1971 Ski Doo Olympic
1973 Ski DooTNT Silver Bullet
1974 Ski Doo Elan 250 Twin (still have, SOLD!!!)
1976 Ski Doo Everest 340
1979 Moto Ski Super Sonic 340
1979 Kawasawki Invader 440
1979 Ski Doo Citation 300
1982 Ski Doo Citation 4500
1984 Yamaha Excel V
1990 Polaris Indy 650
1993 Polaris Indy 440 (wife)
1994 Polaris Indy XLT Special (wife)
1993 Polaris Indy Storm 750
1996 Arctic Cat ZRT 800 (finally seen the light!!)
1996 Arctic Cat ZRT 600 (wife)
1999 Arctic Cat ZRT 600 electric start, reverse (wife)
1979 Ski-Doo Citation 300 (kids)
2000 Arctic Cat Thunder Cat
2000 Arctic Cat Z120 (Zach)
2002 Arctic Cat ZR120 (Corey)
2003 Arctic Cat F7 Sno-Pro
200? ??????? ?????? (not sure yet)
Hot Reels is offline   Reply With Quote
Old 02-28-2009, 08:12 AM   #2 (permalink)
Hello??? anybody...............
1984 Yamaha Excel V
Old 03-03-2009, 06:44 PM   #3 (permalink)
69charged's Avatar
dave, you expect people to reply to you when you tell us all this work you did and no pictures?
good work on the install. hope it looks as good as it sounds. i too am running a 36 tooth and it has all kinds of bottom end still. but i wonder if a 12 tooth drive sprocket would be the better choice then you could go back to using a bigger one in the rear and make it down to your 36 again. know what i mean? i am thinking with the 10 tooth driver, maybe a 30 would be nice but that is really moving. ethans 200 is doing about 25-27 mph now with the current set-up. as for your jetting, sorry i cant help as i have yet to install my 22mm carb. ethan would be pissed if i took it out of service again to put that in, so it will have to be a summer mod along with the chromoly arms i am making for it.
anyway good to hear you get er in there. now i can come to you for ideas on jetting when i get mine on!!
clarence
You might not be the best lookin girl here, but beauty's only a light switch away.
69charged is offline   Reply With Quote
Old 03-04-2009, 07:15 AM   #4 (permalink)
Hello??? anybody...............[/b]
Sorry no pics...... but here is a video of it installed and running.
ZR200HO
It currently has a 10 tooth clutch and a 30 tooth rear. Seams decent except our snow is $hit and pretty near gone.........
The 26 was a little to tall, it's now sitting on the bench!
1984 Yamaha Excel V
Old 03-11-2009, 07:30 PM   #5 (permalink)
ZR200HO
The 26 was a little to tall, it's now sitting on the bench![/b]
.... Hi I did the honda gx 200 install earlier. What you (2) using for an exhaust. rec motors for $124.00? Any other less expensive options.
momojohnny is offline   Reply With Quote
Old 03-12-2009, 07:31 AM   #6 (permalink)
I used a piece of 1" stainless steel tubing which we have at work. I bent it with a tube bender, again from work and bought one of these: RLV Baffle
It's louder than stock but not ridiculous.
1984 Yamaha Excel V
Old 03-14-2009, 01:38 AM   #7 (permalink)
69charged's Avatar
like dave, i made my own out of 1" o.d. pipe that was from a school bus seat frame. the muffler i made myself as well out of aluminum pipe and packed it with steel wool for now. kinda rappy and a little too loud so says the wife.
clarence
Old 11-24-2011, 09:48 AM   #8 (permalink)
130 MAIN JET WITH AT LEAST A 17.5 piolt jet i have a 22.5 in mine but alot of the jetting has to do with other mods,so stock 6.5 i would start out with the 130 main and 17.5 piolt jets,needle in the middle,
collinsdad821 is offline   Reply With Quote
Old 11-24-2011, 09:50 AM   #9 (permalink)
also the sled stock with the 200 will pull the gearing of 10-26 no problem,get that gov.out of there tho.let that puppy rev but be carefull and spend the money for a arc flywheel
