Throttle position sensor? - HCS Snowmobile Forums
XFire 136"-141"/Mtn. Cat/M-series This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 03-17-2012, 11:30 AM   #1 (permalink)
Jet Racing's Avatar
Current Sled(s): 11 CF SnoPro 800HO
Default Throttle position sensor?
On my 2011 crossfire 800 upon every start up when I start to press to throttle the sled hesitates or acts like it is going to die. I burp the throttle lever and get the sled moving and it goes away. I noticed this a little last year and now it seems to be getting worse. Could it be the TPS? Is there any adjustment that I can make to it?
Thanks,
Mark
Jet Racing is offline   Reply With Quote
Old 03-19-2012, 12:09 PM   #2 (permalink)
wastedwagesracing's Avatar
Current Sled(s): 2006 Crossfire 6
I am not sure on the current or newer sleds but my 05 had to be adjusted buy a dealer. It is set by voltage. According to position of the throttle plate.
I have 2 many hobbies I cant afford any of them!
wastedwagesracing is offline   Reply With Quote
Old 03-19-2012, 02:08 PM   #3 (permalink)
Cuyuna1's Avatar
Current Sled(s): '09TZ1Turbo,TD4map,clutching,can,intrclr
Previous Sled(s): 02 Pantera 800,95 ZR700,Indy 650,400
Favorite Riding Area: Haliburton - Parry Sound
10-11 Mileage: 2000
Riding Since: 1984
Thanks,
Mark
Check the TSS before thinking TPS.
Cuyuna1 is offline   Reply With Quote
Old 03-20-2012, 03:37 PM   #4 (permalink)
Jet Racing's Avatar
How do I check or adjust the TSS?
Old 03-20-2012, 04:27 PM   #5 (permalink)
Cuyuna1's Avatar
10-11 Mileage: 2000
Riding Since: 1984
Not sure exactly for your sled, but on my '09 Turbo, I took the throttle block apart and disconnected the micro switch that was "cammed" by the throttle lever pin. The kill button still remained functional and my stumbling problem went away. The gap measurement to the microswitch was out, resulting in a false condition interrupting ignition. Not sure if the wiring is the same on your sled, could be normal open or normal closed. Maybe someone can chime in.
Old 03-20-2012, 05:36 PM   #6 (permalink)
catmandu's Avatar
Current Sled(s): 2010 xfire 800 H.O.
Previous Sled(s): '06 xfire 7, '03 f-7
Riding Since: 1979
Thanks,
Mark
X2- I have 2010 xf8, only rode it one week in quebec this year, but did notice the same thing.
catmandu is offline   Reply With Quote
Old 04-10-2012, 04:55 PM   #7 (permalink)
Jet Racing's Avatar
Curious to know if anyone else has any input on the wiring for the tss. I would just be happy to disconnect the darn thing and be done with it. The way it is now is a real pain carving in and out of tree lines and carving at slow speeds.
Thanks
Old 05-13-2012, 10:01 PM   #8 (permalink)
Current Sled(s): a hacked togeather Snopro
Previous Sled(s): Xf700, F7sp, F5, ZLs,Zrs, Ext, Jags, el tigre
Favorite Riding Area: Back home In the Yoop
10-11 Mileage: 2000
Riding Since: 1988
just unplug it to test it. or adjust your throttle cable to specs and see if the problem goes away
Greg B. is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
