Cutting Primary Cups - HCS Snowmobile Forums
XFire 136"-141"/Mtn. Cat/M-series This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 03-05-2009, 04:08 PM   #1 (permalink)
Member
I always hear you guys talk about having the primary cups cut - What does this mean, why do you do it and how hard is it to do?
bagoboy is offline   Reply With Quote
Old 03-05-2009, 06:26 PM   #2 (permalink)
DonoBBD's Avatar
If you find the paint warn off the outer edge of the spring it may be hanging up stoping your up shift. You can put in a friction shim to let the spring spin. If the spring can't spin when compressed it will want to grow catching the spider cup. Here is a few pictures and what to look for. Look for the dig marks from the spring. If you run a Ti spring when the paint is warn off it will stick to the aluminum and break.
I have been cutting them back to the brace and dropping in one .060 friction shim.
DonoBBD is offline   Reply With Quote
Old 03-06-2009, 06:56 PM   #3 (permalink)
Don, is the .060" friction shim an AC part? If so, what's the PN? If not, where can I get my hands on one?
Speedwerx single, 13:1 heads, Vforce 3 reeds, 2.5 key, inline fuel reducer, D&D green primary, 77g AC weights, 48-42 helix, Goodwin blue/yellow, D&D SA, BDX shaft, ole's extensions and 2" bar riser, 144x15x2", SLP Powderpros, Boss seat, and a bunch more I can't think of...
duluth141m7 is offline   Reply With Quote
Old 03-08-2009, 02:09 PM   #4 (permalink)
Current Sled(s): 2007 crossfire 1000
Previous Sled(s): 06 crossfire 6 and 7, 98 srx, 97 indy trail
what about the other cup? on the cover
moparmudder is offline   Reply With Quote
Old 03-08-2009, 04:14 PM   #5 (permalink)
DonoBBD's Avatar
Haven't touched the cover at all. It can be done if you want. Just open it to the casting rings you see on it. Just to the edge of the rings.
The frictions shims I have been running are comet shims and they need to be turned down to 2.06" to fit in.
Don.
Old 01-12-2010, 05:25 AM   #6 (permalink)
Hatch's Avatar
Current Sled(s): 2012 800 HC / SP 500 MOD
Previous Sled(s): SX-R, Viper, X-Fire 7
I thought I would dig this up again. I have a question on this. It makes sense to do, but will it cause the spring to slide towards one side or does it stay centered. Also what improvements will I see. Will RPMs go up? Why do you need a shim in there? Dono?
Hatch is offline   Reply With Quote
Old 01-12-2010, 05:43 AM   #7 (permalink)
DonoBBD's Avatar
I thought I would dig this up again. I have a question on this. It makes sense to do, but will it cause the spring to slide towards one side or does it stay centered. Also what improvements will I see. Will RPMs go up? Why do you need a shim in there? Dono?[/b]
This one you see here was cut all the way in. If not cut all the way down there will be a shoulder for the spring to stay centered. Then drop in the frictions shims. I think thunder sports has them in stock again.
Heck I am running mine cut like picture posted with two thin shims and a D&D black primary spring on my little 600. The spring rate is 190-330. It doesn't hang up any more.
Don.
http://www.thunderproducts.com/glide_washer.htm
Old 01-12-2010, 05:54 AM   #8 (permalink)
Hatch's Avatar
Ok, so don't cut it all the way down, leaving a step for the spring to sit in. Do I need to cut it all the way out to the braces or I read only need to take off .080?? And the guide washer will just help it so it moves freer. Do I do the cover the same way? and a washer behide that too? thanks
Old 01-12-2010, 08:21 AM   #9 (permalink)
Current Sled(s): 2012 XF 1100 RETRO + 2012 1100na retro
Previous Sled(s): Many Many KITTYS
Favorite Riding Area: northern wis.-da UP.-On SNOW
16-17 Mileage: 600
15-16 Mileage: 700
14-15 Mileage: 2000
13-14 Mileage: 2300
Riding Since: 70s
Don i like to cut those cups at a 10* angel. As on the newer clutchs 09-10 some of the spiders are casted thinner and you will go throw a little bit.
I cut both cups always makes a more freeer and consistent shift.
70GMCTRUCKS is offline   Reply With Quote
Old 01-14-2010, 02:32 PM   #10 (permalink)
Hatch's Avatar
Well I finally got my spider cups machined out, leaving a step to keep the spring centered. I just cut them out to the braces like Dono said (its about .060) and got the thunder product glide washers. No need to turn the washer down, it fit right in there on mine. Thanks Dono and everyone. Here are some pics!
ID:	419145   Click image for larger version
