| XFire 136"-141"/Mtn. Cat/M-series This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#21 (permalink) | |
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) | |
Current Sled(s): '13 m8 162 ltd
Previous Sled(s): 13m8,09 m1,08 m8, '10 m6, 11 f570, 05 f7ext,03 f7,96 zrt 600
Favorite Riding Area: home / bc
12-13 Mileage: 1800
11-12 Mileage: 400
10-11 Mileage: 2600
Riding Since: 14
world didn't end...lets ride!!! |
#23 (permalink) |
Favorite Riding Area: Backcountry
so, do you have to remove the dd or could you just remove the outer cover with it still in the sled? like we did with a chaincase.....
great instructional post by the way!
What happens at camp.........Stays at camp !!!!!! |
#24 (permalink) | |
Unfortunately you can't do that. It's too tight of a spot and the case cover is too tight a fit to be easily removed. I thought about it as well but it's just not do-able. It's really not that bad to remove, mine would have come out easier had I removed my track tension. |
#25 (permalink) |
I had the catastrophic failure you were talking about happen to mine a few months ago. Riding along quite aways from home and i had been noticing that through out the day there was an increases whistiling sound coming from under the hood. We had an idea it wasnt good obviously, but no rope or anything to tow with. We headed home and made it 3 miles from home when i hit a series of bumps going pretty fast and kaboom...sled revved up and i slowed down. Awful smell coming from it, too. Got it to my buddys and took the dd apart to find that the inside looked like diced up vegetables. Pretty scary sight. No fluid to be found, must have escaped like you said.
I do have a question though...why remove the long bolt from the brake side? All i did was loosen it enough to free the DD and didnt have to worry about losing it/misplacing parts, or to take the belly pan off the side of the sled (05 f6 SP).
The only sport that requires two balls |
#26 (permalink) |
Newbie
nice post, thanks. Just wanted to say that you can leave the DD on the sled to change the fluid. Just pull secondary and then split
the DD cover, letting the old fluid just drop out. Spray everything with a generous amount of brake cleaner, let sit overnight and then re-install with new fluid. I set the sled on it's side to put the RTV gasket on. |
#28 (permalink) | ||
#30 (permalink) |
Current Sled(s): 2006 Crossfires - 600/700
Previous Sled(s): 1998-2002 ZR 500s /2003-2005 Firecats F5s
Favorite Riding Area: Ishpeming MI / Kingston Plains
12-13 Mileage: 1700
11-12 Mileage: 1350
10-11 Mileage: 1500
Riding Since: 00
I removed the bolt from the brake side because it retains the DD against the driver, I pulled it out to be sure it was totally undone from the DD shaft itself, I could have undone it, pulled it out 6" then left it there but really the difference was negligeable. On the Firecats - Yes, leave the bolt laying inside the belly pan - No reason to start drilling rivets - Just loosen the bolt and leave it lay inside the belly pan Nice thing about the Crossfires - They have removeable belly pans or sides , so yes you can remove the bolt completely - Love the access , with the flip out belly pan sides If you really want to get technical when changing the fluid , personally i think the gears should be popped out of the cases , that way you can check the seals and bearings , and really get all the oil/dirt cleaned out - Chances are you will also find metal shavings and gunk on the plastic magnetic pickup retainer for the speedo sensor - It really is a piece of cake popping everything out and putting back together - I have replaced bearings / seals before on my Firecats - Just went through my DD gearcase on my Crossfire 7 and my wifes sled is next
Scott and Julie Frye - 2006 Black Crossfires 600 + 700 2011 Dodge Ram 1500 Hemi Sport Quad Cab 4X4 / Deep Water Blue / Loaded 1971 Dodge Charger Super Bees / 383 Magnum / 440 -6 / Pistol Grip / Slapstick / 3:91 Sure Grip / 4:10 Dana R.I.P. "Blue" 6-04-07 "Kesha" 10-04-08 Siberian Huskies Sadie - Niko / Siberian Huskies |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
