79 enticer 340 burning tons of gas - HCS Snowmobile Forums
2 Strokes This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-01-2012, 06:45 PM   #1 (permalink)
Member
Default 79 enticer 340 burning tons of gas
Hi last weekend I took my 1979 Enticer 340 for a short ride only 25 miles but it burnt over half a tank of gas I was wondering if anyone has any clue what might cause this? I Filled it back up after and I've had it sitting in the Garage with no leakage since then so the tank isn't leaking.
thanks in advance
thebert is offline   Reply With Quote
Old 02-07-2012, 02:21 PM   #2 (permalink)
jay mac doo's Avatar
Current Sled(s): none
Previous Sled(s): 2009 gsx 4-tec
11-12 Mileage: 500
10-11 Mileage: 3000
bet its your fuel pump
mine is doing the same thing
jay mac doo is offline   Reply With Quote
Old 02-15-2012, 02:41 PM   #3 (permalink)
Member
Thanks I'll take a look where would the fuel pump be on the Enticer? and if it is the fuel pump would it not be leaving fuel in the bottom of the engine pan?
Old 02-15-2012, 05:33 PM   #4 (permalink)
The fuel cut off valve (a k a, inlet needle ) is not shutting off the fuel supply. Fuel is probably coming out of the vent lines. Suprised it's not flooding. Clean it up and you should be fine. Some carb cleaner or seafoam should do the trick.
If you got time to look at the speedo, you're not goin fast enough!! (Thanks brother Brad)
bguy is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
