| 2 Strokes This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
Current Sled(s): 07' M1000 162
Previous Sled(s): ALOT!!!
Favorite Riding Area: West/northern MN
10-11 Mileage: NOT ENOUGH
Riding Since: 1990
Guy at work Brought me his 2002 Viper 700 Too replace a piston in it that melted. Got the piston(center cyl) put it in, looked over at the Mag Side, Scored too hell too. PTO Side looked Like new. Anyway, Cleaned up the cylinders, lubed her up good, put it back together, Filled it with coolant, left the cap off and ran it at idle for probly 10 or 15 min,put the cap on, took it for a short ride, ran like a million bucks! no problem., check coolant level, good, park it, he comes too pick it up the next day. takes it for ride before he loaded it, ran great, no problems. Takes it home runs it for awhile, dies, Locked up. Gets it home, he tries it a couple days later, starts up, runs, takes it for a short ride, same thing, locks up. Im thinking it Has too be getting Hot but no coolant lights he says. ? He has a hole in one heat exchanger that leaks very slow and he always checks the coolant....Im lost....Any suggestions? Thanks.
SMP MOTORSPORTS |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Member
Current Sled(s): Piped 2003 Yamaha Sx viper ER
Previous Sled(s): 1997 Polaris Classic 500
Favorite Riding Area: U.P.
Stock vipers have cooling problems. That may be the problem. Does your friend have a heat exchanger in the rear? Vipers didnt come with them but people put them on vipers for extra cooling. Also you can buy an aftermarket head gasket for it from Bender Racing that also helps even out cooling.
#3 (permalink) |
Current Sled(s): 98 SRX 700 Race Ported
Previous Sled(s): 79 Liquifire 440
Favorite Riding Area: On my sled
Riding Since: 1990
Pop the head off and see if the piston is melting again. The mag cyl on vipers needs the needle raised with the crappy gas these days and the hot ignition timing on Vipers. The stock head has an eddy in the cooling on the mag cyl which makes that side run even hotter. Without fixing this stuff and cruising at trail speeds (35-55mph)and running ethanol regular gas (crap gas) you are asking for a burn down again.
America loves SPEED! Hot nasty bad ass speed. Eleanor Roosevelt |
#4 (permalink) |
Member
Current Sled(s): 2003 SX Viper
Favorite Riding Area: Rusk County
Riding Since: 2000
Check the pump settings. throw a rear cooler and opticool head gasket on and your good to go.
WITT RACING # 341
#5 (permalink) | |
Current Sled(s): 2009 pol. turbo fst switchback
Previous Sled(s): 1997 vmax sx , 07 I. Q. cleanfire ,03 viper, 99 vmax
Favorite Riding Area: Groton vermont
Riding Since: 2001
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
