1980 exciter oil pump leak - HCS Snowmobile Forums
2 Strokes This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 12-03-2015, 07:59 PM   #1 (permalink)
proxjc's Avatar
Current Sled(s): 2016 Ren. 600, 2015 Ren 1200, 07 IQ 600
Previous Sled(s): 07 800 renegade, 04 F7, 03 ProX 800
Favorite Riding Area: UP
16-17 Mileage: 300
15-16 Mileage: 1200
14-15 Mileage: 1300
Riding Since: 1990
Default 1980 exciter oil pump leak
I got a 1980 440 exciter with an oil leak that seems to be internally in the pump itself. I pulled the speedometer cable out of the housing, cleaned the area, in a hour or so oil is coming out of the speedo cable hole again. Any ideas what would fail inside the pump to let gravity feed oil out of the housing?
proxjc is offline   Reply With Quote
Old 12-16-2015, 11:23 AM   #2 (permalink)
Current Sled(s): 98 SRX 700-99XCSP700-92XCR440-84Bravo
Previous Sled(s): 93 XLT, 85 Vmax, 79 Exciter, 72 Cheetah
Favorite Riding Area: Northern WI, and Michigan UP.
Riding Since: 1980
I had a '79 a long time ago and I'm trying to picture the speedo cable and why engine oil would be coming out of that ? Maybe I'm not remembering correctly, but isn't the speedo housing located down on the drive shaft behind the secondary like any other sled ?
98 SRX 700.
Original owner- 14800 miles
Original untouched stock motor
clutched & gears
168 picks
117.6 mph--gps--packed snow
Speedo said 129/130
17 mpg when trying.
wis98srx is offline   Reply With Quote
Old 12-16-2015, 11:58 AM   #3 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
13-14 Mileage: 1,864
Riding Since: 1959
That's not the speedo cable, it's the Tach Cable.
Old 12-16-2015, 12:27 PM   #4 (permalink)
yamarx1's Avatar
Current Sled(s): Bravo 250 with 251 Big bore kit
It's the tack drive cable. There is a seal where the drive comes out of the oil pump. Unscrew the cable clean it with brake cleaner ( cable and pump) fill the cap with RTV and screw it back on. In most cases it will stop the leak
yamarx1 is offline   Reply With Quote
Old 01-07-2017, 04:31 PM   #5 (permalink)
theres no tach cable to the oil pump?only the throttle cable to open and close pump no?
blackjack1 is offline   Reply With Quote
Old 01-07-2017, 06:16 PM   #6 (permalink)
Backwoods M Max's Avatar
Current Sled(s): 02 MM700, 99 Indy SKS, 99 Formula DLX
Previous Sled(s): 86 Polaris Indy 600
Favorite Riding Area: Between the trees
15-16 Mileage: It's
14-15 Mileage: All
13-14 Mileage: About
Riding Since: 2009
If your talking about the angle drive adapter from the drive axle below the secondary I can offer you this. Ski doo on the elan and other old sleds used a hollow drive axle to allow oil to pass through and oil the clutch side drive axle bearing. Did Yamaha do this but with the complexity of a speedo drive...I don't know. It's possible but first let's figure out what cable you are actually talking about. That engine should be digital CDI so it's easy to get a tach signal off the pickup.
Custom 151" Mountain Max
Indy 700 SKS
"We're having a hard time keeping people moving in the direction we need to go.....because the snow is deep"
Backwoods M Max is offline   Reply With Quote
Old 03-20-2017, 01:28 PM   #7 (permalink)
i have a 85 exel 111 it is doing the same thing as the OP, it is the tach cable leaking, is it a seal in the oil pump? so how do I fix the leak and keep the tach in operation
thanks
06 f7 std efi, rktek head for 91, d&d y bmp pipe, stm secondary, 1.5 track, boss seat
canf7 is offline   Reply With Quote
