Bleeding Air from Cooling System - HCS Snowmobile Forums
4 Stroke Cats 1100 Turbo / 1100NA / Z1 Turbo / Z1 / T660/ This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 01-16-2010, 06:57 PM   #1 (permalink)
turnerrd's Avatar
Current Sled(s): Sidewinder LTX-LE Priceless Edition
Previous Sled(s): 3 Cat Turbos
Favorite Riding Area: W.NY, Mich, Lake Erie ICE!
15-16 Mileage: 2200
14-15 Mileage: 2500
13-14 Mileage: 2000
Riding Since: 1979
Does any one have the official procedure? Hints, Tricks
Thanks
Rob
"Just Hold It"
turnerrd is offline   Reply With Quote
Old 01-16-2010, 07:31 PM   #2 (permalink)
motorcitysteve's Avatar
Pictures would help, but the bleed screw on the head is between the two exhaust ports. From the service manual is below.
FILLING/BLEEDING COOLING
SYSTEM
1. Remove the hood and the left-side and right-side
access panels; then remove the torx-head screws
securing the console.
2. Move the console up and forward; then with the
harness connected, securely position the console
on the snowmobile.
3. On the non-turbo models, remove the headlight
support bracket/heat shield.
4. On the turbo models, loosen the cap screws securing
the heat shield to the exhaust manifold/turbocharger;
then using a deep socket and hammer, tap
the washers making sure that the washers are free
from the head of the cap screws. Remove the cap
screws and move the heat shield to access the
bleed screw.
5. Loosen the bleed screw and add coolant into the
filler neck until coolant is visible at the bleed
screw; then tighten the bleed screw and add coolant
to the coolant reservoir Full-Cold line.
6. Start the engine and allow it to run for five minutes.
7. With the engine cool, loosen the bleed screw and
allow the coolant level in the filler neck to drop;
then with the bleed screw loose, add coolant into
the filler neck until no air is visible or heard at the
bleed screw. Tighten the bleed screw and add coolant
to the reservoir if necessary.
��NOTE: If the coolant level in the filler neck suddenly
drops when the bleed screw is loosened, an
air-lock occurred in the cylinder head. Add coolant
to the filler neck until full before starting the
engine.
8. Start the engine and allow it to run for five minutes;
then shut the engine off and allow it to cool.
9. Repeat steps 7-8 at least two more times (more if
necessary) until no air is in the cooling system.
! CAUTION
Be sure the cooling system is thoroughly filled and
bled using the following procedure.
! CAUTION
The Filling/Bleeding Cooling System procedure must
be followed very closely and the cooling system must
be properly filled. If the system isn’t properly filled,
engine damage will occur.
! CAUTION
Use care not to allow the console harness to come
into contact with the exhaust pipe during this procedure.
! CAUTION
Make sure the washers are free from the head shield
cap screws or damage to the heat shield will occur.
! CAUTION
Running the engine with low coolant level can cause
severe engine damage.
! CAUTION
Operating the snowmobile with air in the cooling system
will cause severe damage to the engine.
10. On the non-turbo models, install the headlight support
11. On the turbo models, place the heat shield into
position and secure with the cap screws. Tighten
the cap screws to 96 in.-lb.
��NOTE: Apply a film of anti-seize to the threads of
the heat shield cap screws before installing.
12. Position the console assembly on the headlight
support bracket; then secure the console with the
two torx-head screws.
13. Install the hood; then install the side access panels
and secure with existing mounting hardware.
Steve
motorcitysteve is offline   Reply With Quote
Old 01-16-2010, 11:57 PM   #3 (permalink)
If possible, lift the front of the sled as high as you can get it. If you dont, you will be repeating steps 6,7 and 8 so many times, you will think will this ever end...??
My skis were 12 inches of the ground before I could get all the air out. Took me 6 times of the 6-8 steps after I raised it up that high.
Agrat is offline   Reply With Quote
Old 01-17-2010, 10:20 AM   #4 (permalink)
turnerrd's Avatar
15-16 Mileage: 2200
14-15 Mileage: 2500
13-14 Mileage: 2000
Riding Since: 1979
Thanks Steve and Agrat. I opend the srew up last year to bleed it when my coolant resevoir line burnt, but didn't follow any specific procedure.
"Just Hold It"
