2007 Jaguar Z1 Spark Plug CHANGE F*&^ A(*%@!!!!! - HCS Snowmobile Forums
4 Stroke Cats 1100 Turbo / 1100NA / Z1 Turbo / Z1 / T660/ This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-02-2009, 01:48 PM   #1 (permalink)
michigancrusher's Avatar
Smile
OMG!
I been having a few issues with my girfriends Jagz1. stalling, hard starting........etc. SO what would any normal person do.................Start with the fuel filter and Spark plugs.
Holy mechanic school. I had to remove side panels, seat, handlebars, gas tank frame, gas tank, and then the air box! Who is the DUMB Engineer on this one! Thank god this is not a 2 stroke!
michigancrusher is offline   Reply With Quote
Old 02-02-2009, 01:54 PM   #2 (permalink)
rgnbull1227's Avatar
Current Sled(s): 2015 XF9000 Turbo LE HJ 2.0, Meth, ECC, etc.
Previous Sled(s): 2012 F1100 Turbo LE HJ 2.0, Meth, ECC, 2009 HyJacked Z1Turbo
Riding Since: 1981
OMG!
Holy mechanic school. I had to remove side panels, seat, handlebars, gas tank frame, gas tank, and then the air box! Who is the DUMB Engineer on this one! Thank god this is not a 2 stroke![/b]
Actually. My dealer told me to get at the plugs, all you have to do is remove the 2 screws on on either side of Bars and the entire piece comes off and you can get access to plugs.
rgnbull1227 is offline   Reply With Quote
Old 02-02-2009, 03:17 PM   #3 (permalink)
zoso
Guest
Posts: n/a
Actually. My dealer told me to get at the plugs, all you have to do is remove the 2 screws on on either side of Bars and the entire piece comes off and you can get access to plugs.[/b]
Time for new dealer.
Old 02-02-2009, 03:22 PM   #4 (permalink)
dt6957's Avatar
Current Sled(s): 2014 ZR6000 RR
Previous Sled(s): 2008 F6 LXR (wife)
Favorite Riding Area: Hudson Bay
Riding Since: 1978
Not an easy task.... I took mine to the dealer!!
$200.00 later, I had new plugs!!! Oh well, I have saved that in oil I guess. LOL
Hopefully they find a way to make it a little easier!
Cat History:
1976 Cheetah 5000
1997 Cougar 550
1998 ZR600efi Limited
1997 ZR440
2000 ZR600efi Limited
2002 ZR800efi Cross Country
2003 F7 Sno-Pro Team Canada
2000 ZRT600 Limitied
2002 ZL550esr
2002 ZR800efi
2004 Sabercat 600lx
2003 F7 Sno-Pro Team Arctic
2005 Sabercat 600efi
2006 Crossfire 600
2007 F6
2008 F6 LXR Pink (wife)
2008 Jaguar Z1 Black
2008 Jaguar Z1 Green
2010 Z1 EXT Turbo
2012 F1100 NA 50th edition black sno-pro (order)
dt6957 is offline   Reply With Quote
Old 02-02-2009, 03:28 PM   #5 (permalink)
zoso
Guest
Posts: n/a
It really is not that hard, but does take time. The thing is, with this sled it would not be the first place to look for an issue anyway. Iridium upgrade is good everyone has to go in there to check the valve clearance eventually so change the plugs at that time as well as clean the air box etc. High tech toys are lots of work to keep mint, but as long as I am not down in the dead of winter I like work on the sleds in the off season. My sled has had minimal issues and they were all easy fixes. There is a split airbox upgrade to allow access to the plugs.
Old 02-02-2009, 07:01 PM   #6 (permalink)
catchmeifucan's Avatar
Current Sled(s): 2012 F1100T SP LTD, 2007 Attak
Previous Sled(s): 1996 TCat 1004, PS1000 Cat
Welcome to the 4 stroke world!
Plugs on yammies no fun either.
and the oil filter is just fun fun fun!
catchmeifucan is offline   Reply With Quote
Old 02-02-2009, 07:29 PM   #7 (permalink)
krom's Avatar
Current Sled(s): 09 Sno Xer
Favorite Riding Area: South of the Hill
The oil and filter on all cat sleds are easy to get to.
On the turbo sleds plugs can be extracted with the pod off, and a U-joint. The non turbos require the gas tank and air box to be removed.
krom is offline   Reply With Quote
Old 02-02-2009, 07:38 PM   #8 (permalink)
Snowride's Avatar
On the turbo sleds plugs can be extracted with the pod off, and a U-joint. The non turbos require the gas tank and air box to be removed.[/b]
I figured you could get to it with just the pod off but it did look like you needed to remove the intercooler manifold. Guess I assumed wrong. Thanks Krom
2013 TZ1 Turbo Limited
04 Polaris 700 EFI (Quad)
Snowride is offline   Reply With Quote
Old 02-03-2009, 02:41 AM   #9 (permalink)
Smile
I figured you could get to it with just the pod off but it did look like you needed to remove the intercooler manifold. Guess I assumed wrong. Thanks Krom[/b]
I am very disapointed with Arctic Cats engineering on this one. I had to get assistance to try to align up the boots on the carb. No room! I used a mirror to see under the airbox which helped out alot. Someone said Actic cat had a upgrade by a separated air box, this one separates side to side. Not sure if this was the upgrade but if it is they can shove it up there ass and re up grade it. I have been a Cat fan for over 20 yrs, but I am considering making the jump.
I heard that if u tip them over, u have to do the same thing, remove plugs airbox etc. What happens if ure in the U.P and tip it on its side. HMMMM..... UR F*&^%
Old 02-03-2009, 03:44 AM   #10 (permalink)
jamm's Avatar
Current Sled(s): 2013 Turbo RR, 2009 TZ1 Turbo
I heard that if u tip them over, u have to do the same thing, remove plugs airbox etc. What happens if ure in the U.P and tip it on its side. HMMMM..... UR F*&^%[/b]
The Z1 engines are using "Dry Sump" oil system. Tipping to a side, for a short time, does not harm engine oil system.
The hidden flaw never stays hidden for long
jamm is offline   Reply With Quote
