| ZR/ZL forum This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
I am the second owner of this sled. Went to put a handlebar riser on. When I removed the pad, the 3 wire plug was disconnected. If I plug it back in, it dies when I take off. If this is the throttle position sensor, how do I correct it? Is it in the handlebar housing I need to look, or is there an actual sensor that could be bad?
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Current Sled(s): 02 ZL600 EFI SS
Previous Sled(s): 05 Sabercat 600, 01 zr800 136"
Favorite Riding Area: Nash Stream, Bingham
Riding Since: 1981
It's not a throttle position sensor, it's called a TSS or throttle safety switch. Do a search or 2 on here and you'll find lots of info. Basically either try replacing the little plastic bushings and pin for the throttle lever and if that doesn't work you need a new assembly. Very common on cats.
02 ZL600 EFI 05 sabercat 600efi 05 ZL550 ESR 01 ZR800 136" 01 ZL500 ESR 98 ZR600 EFI 01 ZR600 EFI LE 92 EXT SP 91 EXT SP 72 Panther 85 Cougar 500 81 El Tigre 500 78 Jag 340 |
#3 (permalink) |
That plug controls the tss and the killswitch ones a ground wire and the other 2 are power for each one. Now while your sleds running take a piece of wire and jump it from the single male end on the sled side of the plug to one of the female plugs also on this side once you find the killswitch tape the wire into place and you've bypassed the tss
#4 (permalink) |
Current Sled(s): 1997 ZRT 600/2003 1M 900
Previous Sled(s): 1995 Powder Special, 1996 ZR 580
Favorite Riding Area: Cooke City, Montana USA
10-11 Mileage: LOTS!!
Riding Since: 1977
Depends on what year you are talking about. You have your closed and open ignition systems. If it runs with plugs unplugged, you have an open system. Vis versa for the closed system.
'98 they started with open systems... Good luck..
#5 (permalink) |
Riding Since: 1981
What year and sled are we talking about?
#7 (permalink) |
Current Sled(s): 99 ZR 711
Previous Sled(s): 340 indy, miniz
Riding Since: 3
Previous owner already disconnected it. Sleds are known for it. Leave it unplugged.
Out of curiosity is this a mountain cat or pantera or something? Sent from my MB860 using Snowmobile.com App |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
