| ZR/ZL forum This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
My sled has d&d twin 1010 pipes as well as the d&d clutch kit. All I have done was increase the main jets to 560 mains and adjust the air screws. Here is where my question comes in. I want to put a power breather on my sled but do not understand that much about low speed carb tuning. I know how to check full throttle by flipping the choke open while holding it wide open and seeing if it bogs down or picks up. How do i do low and mid range tuning? strictly by reading piston wash? I was told to raise the needle one clip position and adjust the fuel screws from there. Can anyone shed some light on this for me. I have spent the last two days trying to find a good tuning article or similar setups. I also have the typical rising idle that eventually falls with these sleds, many people say to just leave it alone. If anyone has a good writeup on the mikuni flat slide carbs for these sleds it would be greatly appreciated. thanks
98 Thundercat 1000 03 ZR900 |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Current Sled(s): F-1000
Previous Sled(s): 77 ElTigre
Favorite Riding Area: Perkin's Clearing
11-12 Mileage: not enough
Riding Since: 1972
I dont know if Id raise the clip as it leans the mid, Im pretty sure I remember some Guys using F7 needles that have a different taper. Perhaps a call to D&D would shed some light on a good baseline, dont expect to pass a gas station with those mains.
#3 (permalink) |
One of their techs told me to raise the clip on the needle and adjust from there. Actually my gas mileage is about the same with those mains as with the sled the way it was stock. I am going to try and call them tomorrow to get to the bottom of this.
#4 (permalink) |
you sure that they didn't say to "raise the needle a clip"? (richer). it's easy enough to try it either way. IMO, 560s are plenty rich and like you believe they said, you may need to lower the needle (leaning it) to get it to be crisp enough off the start, just know that this is going to lean your midrange/cruising rpm and you will need to be aware in that area.
#5 (permalink) | |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
