2001 ZR 800/900 Handling Suggestions - HCS Snowmobile Forums
Old 02-28-2011, 04:11 PM   #1 (permalink)
Koenig's Avatar
Current Sled(s): 04 zr900,01 ZR800/900
Previous Sled(s): 93Wildcat,01Z370,72SkiRouleRTX,68SupOlym
Riding Since: 1970
Default 2001 ZR 800/900 Handling Suggestions
Hi, recently new to me 01 Zr 800 with carb'd 900 top end and pipe, Predator track, about 9" carbides. Excellent accel, but handling has me thinking it could be a lot better. Just finished a 250mile trip Sat/Sun, good base! Corners tended to steer hard then lift the ski, wearing me thin (I'm an older guy!LOL!) The only fix/ adjustment that seemed to work while riding was to brake early, and then accelerate consistently through the corner. If I let off (ex. rider coming opposite direction) the skis tended to lift and the machine would get 'squirrelly' ! I was looking through a document "AC Susp_setup" this am to get some ideas. The machine was used as a lake rocket by the previous owner so keep that in mind as I have not verified all suspension mounting holes. The front shocks are set on dial#1 with springs moderately loose, 'snug' would be a better word. Rear end springs are set on #2 (of 3)((should be on 3, as I'm just over 200lbs)))) The Rear shock handlebar adjustment was 'done away' with when it broke a few years ago (says P.O.) reg gas shock there now (don't know how much spring coil tension is on that shock. I was told rear shocks were rebuilt 1.5 years ago.
So... looking for handling suggestions, and observations? Just love this sled but want more!
best,
Sandy
Koenig is offline   Reply With Quote
Old 02-28-2011, 04:23 PM   #2 (permalink)
bluelightning426's Avatar
Current Sled(s): Whatever HSS Gives Me To Ride
Previous Sled(s): 2003 ZR "800" Sno Pro
Riding Since: 1997
Does it have coupler blocks in it?
bluelightning426 is offline   Reply With Quote
Old 02-28-2011, 05:35 PM   #3 (permalink)
Koenig's Avatar
Riding Since: 1970
Hmm... wish I could answer that.... don't know what they are? I assume they're located in the skid....? I'm off to the cottage tomorrow, so I could verify... need to be enlightened as to where/what to look for. Are these 'aftermarket' parts? My reading has led me to believe these ZRs' were great out of the crate!
Old 02-28-2011, 06:13 PM   #4 (permalink)
gunner f5's Avatar
Current Sled(s): 12' SBA 800
Previous Sled(s): 02' ZR800 efi CC 136" Cobra / 03' F5 SnoPro
Favorite Riding Area: Da' UP
Riding Since: 92'
best,
Sandy
On the bold, that is the correct way to maintain highest average speed thru a corner. Charging a corner hard, braking to the point of the track locking up and sliding, then pinning the throttle and thus spinning the track looks and feels cool but is not the fastest way. Now in a 90 deg turn, that's a different story.
Sounds like your limiter straps are too tight. Also, you need to run the front coil spring on the rear skid just tight enough to prevent it rattling. You will need to place the sled on its side to adjust it properly.
gunner f5 is offline   Reply With Quote
Old 02-28-2011, 06:56 PM   #5 (permalink)
Riding Since: 1997
It's 2 black blocks that go right behind the rear scissor arm. What it does is keeps more ski pressure and doesn't allow so much weight transfer and keeping your ski's on the ground better. I don't think 2001 ZR 800s came with them but it's easy to put them in. Heres a pic of what to look for. I circled the blocks.
Old 02-28-2011, 08:18 PM   #6 (permalink)
Current Sled(s): Renegade Back Country 800
Previous Sled(s): ZR900
13-14 Mileage: 1750
Riding Since: 93
From the sounds of it you need to tighten you limiter strap to put more pressure on the skis. If you are just having a hard time turning the skis themselves then you need to drop your carbide size to a smaller one. If it pushes to the outside of the corners there is not enough ski pressure.
I run 10in carbides with plenty of ski pressure and it turns in great very little push through the corner. It lifts the inside ski off the ground if I turn tight but that is better then pushing through the corners. I also have a heavier sway bar that contributes to the inside ski lifting.
Air_Jordan99 is offline   Reply With Quote
Old 02-28-2011, 08:59 PM   #7 (permalink)
Koenig's Avatar
Riding Since: 1970
Ok... one suggestion to tighten limiter strap, another suggests it's too loose... I guess after more thought, rather than pushing to the outside, the machine would create a 'tippyness' unstable feel, ski float, 1/4 through a fast corner and then push. I'm an old fart that used too professionally roadrace Yamaha TZ750's/250s' in the 70/80's throughout N.A. so handling is a 'premium' to me. Not spent much time on this machine until this W/E (no snow, everywhere but here!), but love that feel of 'instant accel/smile' that the 900 puts out... I haven't really gone through the suspension yet, thus the question, and will spend the day tomorrow assessing the machine.
On the status of 'blocks'... I don't remember seeing them(but memory is another point in my life LOL!) will verify tomorrow. Thank you for the explanation....
Smaller carbides was one of my thoughts as well. When I purchased this sled, the P.O had dozens of 'screw in' studs and it hooked up quite well, certainly more than my old Wildcat.... but the studs have 'disappeared' due to lack of snow, and therefore maybe to much Carbide up front.
Thanks to all who have contributed so far....
Old 02-28-2011, 09:41 PM   #8 (permalink)
gunner f5's Avatar
Riding Since: 92'
Sounds to me like you are experiencing the classic "teeter totter" effect.
Steers hard off the throttle, then picks the skis up on the throttle. You're already light in front ski spring pressure so I would loosen the straps some and keep your but planted up near the tank when applying throttle coming out of the corner. As you know, where and when you move your body weight on the sled will largely influence the weight transfer characteristics, especially when your over 150 lbs. Just play with the straps and ski pressure. Keep in mind that carbide length doesn't play that much of a role unless the trails are icy or extremely hard packed. Sounds like you may want to think about aftermarket skis that have a more aggressive keel. That way you can run your set up more "neutral" and not worry about adjusting for each different snow condition. I run Powder Pros on my 800 with 9" shaper bars with very little steering effort required to turn.
Old 02-28-2011, 10:02 PM   #9 (permalink)
Koenig's Avatar
Riding Since: 1970
I think your 'right on'. I did find the further back I sat, the worse it became. I joked with my son that I needed to sit on the 'handlebars' and everything would settle down..heheh! Would loosening the tension on the center shock spring (I have no idea where it's set at) lower the teeter/totter affect? Or would that create another problem.
The other memory of the ride was a slight 'hunting' feeling on straight-aways, unless at a higher speed (then my concentration changed to self preservation!
I should add that there are 2 holes for both the frt and rear mountings of the skid on this machine (again not sure if the previous owner had a hand in producing more adjustments for his lake racing) the 2 holes are about 1 inch vertical of each other, frt & rear. Is this standard! I know the old Wildcat had some 'lift' adjustment, but they were in the rear only, above or below the footrail. These holes are in the tunnel.
Old 02-28-2011, 10:05 PM   #10 (permalink)
kawicat's Avatar
Call Fett Bros and get their RIDE TECH shock package. You will be able to do stuff that will amaze you. Into the corners without brakes and zero brakes. Well worth the money.
kawicat is offline   Reply With Quote
