2003 zr 800 efi tss - HCS Snowmobile Forums
Old 02-23-2011, 11:05 PM   #1 (permalink)
paterman's Avatar
Default 2003 zr 800 efi tss
Does anyone know how to by-pass the Throttle Safety Switch?
Nickel
paterman is offline   Reply With Quote
Old 02-23-2011, 11:53 PM   #2 (permalink)
priesman64's Avatar
Current Sled(s): 1998 Arctic Cat ZR 600
Previous Sled(s): 2003 Arctic Cat Sno Pro 440
3 prong plug near handlbars (purple, black, brown) unplug and see if problem persists. I believe the kill switch will not work then. If it is the tss causing a problem then you can cut the black wire in that 3 prong plug and its good to go.
priesman64 is offline   Reply With Quote
Old 02-24-2011, 06:06 PM   #3 (permalink)
bluelightning426's Avatar
Current Sled(s): Whatever HSS Gives Me To Ride
Previous Sled(s): 2003 ZR "800" Sno Pro
Riding Since: 1997
When i unplugged my TSS the kill switch still worked
bluelightning426 is offline   Reply With Quote
Old 02-24-2011, 09:54 PM   #4 (permalink)
paterman's Avatar
Thanks priesman, unplugged it but didn't cure my issues. Pretty sure it's the stator...
PS, with the TSS unplugged my kill switch did not work...
Thanks again,
Nickel
Old 02-24-2011, 11:43 PM   #5 (permalink)
priesman64's Avatar
blue, the plug by the carbs will allow the switch to work. if you completely unplug that 3 prong though it has no connection to the kill switch anymore.
pater.. good luck with the issue.
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
