compression - HCS Snowmobile Forums
Old 02-02-2011, 07:52 PM   #1 (permalink)
Current Sled(s): 02 zr 600 cc
Previous Sled(s): xlt
Default compression
02 zr 600 cce. Just did a rebuild. get a compression of about 110. sound about right?
nickmayo is offline   Reply With Quote
Old 02-02-2011, 08:01 PM   #2 (permalink)
smittyseng's Avatar
Current Sled(s): 14XFturbo, 12F800, 11Z1T
Previous Sled(s): 03ZR9 01ZR8 02 570 01ZR440 98ZR6 98ZR440 97ZR440's 96ZRT800
Favorite Riding Area: Michigan
Riding Since: 1976
Try a different gauge, 110 is pretty low, especially for being fresh!
smittyseng is offline   Reply With Quote
Old 02-02-2011, 08:38 PM   #3 (permalink)
my 99 zr 600 after 4000 miles was at 124
zrman68 is offline   Reply With Quote
Old 02-02-2011, 08:45 PM   #4 (permalink)
SShooterZ's Avatar
Current Sled(s): 2017 ZR8000 SP
Previous Sled(s): 2003 Z440 SP | 2002 ZR600 | 2000 ZR600 | 1996 580EXT EFI
2000 ZR with 4800 miles was around ~120-125
Definitely sounds lowish for a rebuild.
SShooterZ is offline   Reply With Quote
Old 02-02-2011, 08:54 PM   #5 (permalink)
ill check it again in the morning. it was a used piston and cylinder that we got.
Old 02-02-2011, 10:13 PM   #6 (permalink)
Current Sled(s): "Agri-vator"
ooo. should be 120ish. but try a different gauge first. what does the other side read? if they are both 110, perhaps you just have a gauge that reads low
Old 02-02-2011, 10:25 PM   #7 (permalink)
Favorite Riding Area: city streets of burton MI
I`ve found that quite often cheaper gauges with long hose`s will read low...I have two of them, both read low..
(have a friend that lives right down the road, i`ve compared both my gauges to his snap on gauge..BIG difference!)
look for evenness..if their both about dead even, or atleast within a couple lbs, your probley good to go..
also, be sure to hold the throttle wide open when you test..
Fixerupper is offline   Reply With Quote
Old 02-03-2011, 01:41 AM   #8 (permalink)
D&D800's Avatar
I believe max compression was 135 from the factory. I generally look for the compression to be within 10% where as mentioned above a lot of gauges read low. I generally test with the key off (I know this sounds dumb but people forget sometimes), engine warm, throttle open, and 2-3 good pulls.
D&D800 is offline   Reply With Quote
Old 02-03-2011, 08:04 AM   #9 (permalink)
ready2race's Avatar
Current Sled(s): 06" F 7- R
Previous Sled(s): 00 ' ZR 500 96" ZR 580 ,,Z440
Favorite Riding Area: 660FT
Riding Since: 1970
i agee ...my 500 was about 135 so i would think the 600 would be around that..
WIN....LOSE..OR .....DRAW
ready2race is offline   Reply With Quote
Old 02-03-2011, 04:49 PM   #10 (permalink)
i was always told that even if the compression is low as long as there the same in each cylinder that it should b ok
