ZL600 EFI Clutch Spring - HCS Snowmobile Forums
Old 11-04-2004, 09:21 AM   #1 (permalink)
insearchofsnow's Avatar
Current Sled(s): 2015 ZR 7000 ET LTD
Previous Sled(s): 07 F6 LXR, 06 SCat 600 LXR
Favorite Riding Area: UP Michigan & Algoma
13-14 Mileage: 1500
Riding Since: 1977
Both my 2002 ZL 600EFI and 2000 ZL600EFI have a Ylw-Grn spring (#0646-147) on the primary clutch. The Arctic parts manual suggests (for below 9000ft alt) that the stock 2002 spring is Red (#0646-149) and 2000 spring is Ylw-Wht (#0646-229).
Is the Ylw-Grn spring a better all-around spring for the 600 sleds? Is it likely that these springs were changed out to Ylw-Grn at some point as I bought them used?
I ride in Ont & UP which I believe is 600-1000ft above sea level.
insearchofsnow is offline   Reply With Quote
Old 11-04-2004, 12:51 PM   #2 (permalink)
Previous Sled(s): Yamadoocatpoo
Favorite Riding Area: Where it snows
Riding Since: 1972
It sounds to me that they have been changed to a ZR set up. I would also check the weights/cams.
2001 ZR600 have the Y/G spring with 539 cams, 4,000 engagement spec.
2001 ZL 600 calls for a Red spring with 592 cams, 3500 engagement spec.
My 2000 ZL600 has a Yellow/White spring with 609 cams, 4,200 engagement.
Here are the spring charts from my 2001 manual for comparison.
SPRINGS -
ARCTIC DRIVEN
p/n Color Rate @ 1 7/16"
0748-025 Green 157 lbs.
0648-114 Red/White 113 lbs.
0148-227 Yellow 92 lbs.
0648-012 Blue 79 lbs.
0648-010 White 58 lbs.
0148-176 Black 42 lbs.
ARCTICCAT DRIVE CLUTCH SPRINGCHART
p/n - Rate@ 2 9/16 in. - Rate@ 1 5/16 in. - Color
LIGHT 0646-148 53 lb 224 lb Red/Blue
0646-150 72 lb 188 lb Silver
0646-149 74 lb 228 lb Red
0646-147 114 lb 267 lb Yellow/Green
0646-155 121 lb 240 lb Purple
0646-229 122 lb 285 lb Yellow/White
HEAVY 0646-248 143 lb 290 lb Orange/White
NOTE: The Arctic Cat drive clutch spring has a smaller O.D. than the
Comet and cannot be interchanged.
polcat is offline   Reply With Quote
Old 11-04-2004, 02:04 PM   #3 (permalink)
13-14 Mileage: 1500
Riding Since: 1977
The 2002 has 520 cams YL/GR spring.
The 2000 has 485 cams YL/GR spring.
I had the clutch rebuilt on the 2000 by dealer, they did'nt change spring but did order 485 stock weights and I am wondering if this is why the clutching seems different. On hard braking, the motor seems to take longer to come back to idle.
I don't really understand the spring rate/cam weight relationship but if anybody has any suggestions on what spring or weights I should use that would be great. The cams & rollers are brand new and I would prefer not to have to spend big$ and perhaps only change the spring.
Old 11-04-2004, 04:10 PM   #4 (permalink)
Riding Since: 1972
In short, your 2002 primary clutch set up may indeed be factory for that year, check a Service manual to be sure. Your 2000 is not.
The 2000 should have #0746-609 52.0 grams cams and Yellow/White spring, with a 4-4300 rpms engagement. With that said, your set up of 48.5 gram with Y/Gr spring (that I think you meant by 485) may react very similarly but I suspect that it has a slightly higher engagement speed around 45-4800 rpms?. If you don't like it that high, change it to the 2001 set up above with #0746-592 52 gram cams and Red spring. This will bring the engagement down to the 3,500 range. It worked nice on my 2000 ZL600.
