How to prevent exhaust gases leaking from Y-Pipe - HCS Snowmobile Forums
Old 02-10-2008, 12:19 PM   #1 (permalink)
trdehmer's Avatar
Current Sled(s): 2016 Axys SB 800 ProS & 2015 Axys SB 800 60th
Riding Since: 1984
I've tried the Permatex Ultra Black High heat silcone stuff, Permatex recommended the Ultra Copper as its a bit higher temperature rated and can hold up to vibration better vs. the Ultra Black. Neither have worked. I even put in a new Grafoil gasket, it still leaks at the Y-Pipe and Single pipe junction. The springs are so tight that I can barely get them on, so I don't think the springs are the issue?
Any sugguestions - are there any other options I can try - maybe a better Grafoil gasket? Maybe one off a different sled?
Previous Sleds:
2012 F1100 Turbo 50th
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
1990 Polaris 340 Sport
1984 Polaris 480 Trail
A Phazer
1969 Massey Ferg Ski Whiz
trdehmer is offline   Reply With Quote
Old 02-10-2008, 01:05 PM   #2 (permalink)
After using the permatex did you let it set up before starting the sled? I have had great luck with it. Check the "Y" pipe for cracks.
NH Sabercat is offline   Reply With Quote
Old 02-10-2008, 01:32 PM   #3 (permalink)
bluelightning426's Avatar
Current Sled(s): Whatever HSS Gives Me To Ride
Previous Sled(s): 2003 ZR "800" Sno Pro
Riding Since: 1997
I use the permatex red high temp. Stuff works awesome. I agree with sabercat. After putting it on let it sit and dry. Start it up and get it hot, then shut it off and let it cool down and it makes a perfect seal
bluelightning426 is offline   Reply With Quote
Old 02-10-2008, 01:39 PM   #4 (permalink)
trdehmer's Avatar
Riding Since: 1984
I let it set-up a minimum of 24 hours. It made a great seal, but after the pipes get hot it always burns off then starts to leak. There are no cracks in the pipes.
Previous Sleds:
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
A Phazer
Old 02-10-2008, 05:08 PM   #5 (permalink)
Riding Since: 1997
Use the red/orange stuff. Won't burn off
Old 02-10-2008, 05:37 PM   #6 (permalink)
trdehmer's Avatar
Riding Since: 1984
http://www.permatex.com/products/automotiv...cone_Gasket.htm
Here is what I just tried:
Permatex® Ultra Copper® Maximum Temperature RTV Silicone Gasket Maker
OEM specified. Highest operating temperatures for 4-cylinder, turbocharged or high-performance engines. The most advanced, high temp RTV silicone gasket available. Sensor-safe, low odor, noncorrosive. Superior adhesion. Three times more oil resistant than conventional silicones; eight times more flexible than cut gaskets. Temperature range -75°F to 700°F (-59°C to 371°C) intermittent; resists auto and shop fluids and vibration.
Suggested Applications: Exhaust manifolds/ headers, valve covers, oil pans, timing covers, water pumps, thermostat housings
I haven't tried this one, but the Ultra Copper can handle higher heat?? According to the notes, the Ultra Copper is good for exhaust manifolds as well.
Permatex® High-Temp Red RTV Silicone Gasket
OEM specified. Formulated for hi-temp applications, or heavy-duty use (such as towing, etc.). Replaces almost any cut gasket by making reliable “formed-in-place” gaskets that resist cracking, shrinking and migrating caused by thermal cycling. Coats pre-cut gaskets to increase reliability. Temperature range -65ºF to 650ºF (-54°C to 343°C) intermittent; resists auto and shop fluids. First generation 1970-1980 gasket maker.
Suggested Applications: Valve covers, oil pans, timing covers, water pumps, thermostat housings, transmission pans
Previous Sleds:
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
A Phazer
Old 02-10-2008, 07:21 PM   #7 (permalink)
Riding Since: 1997
Dunno what to tell ya. I've had my pipe on and off countless times. Run a thin layer of the permatex red silicone on the donuts, put the pipe on, let it sit over night if possible and i've never had an issue with leaks. One time i started it and the Y pipe donut leaked a tiny bit. I shut it down, let it totally cool down and it sealed up. Try it
Old 02-10-2008, 09:28 PM   #8 (permalink)
Current Sled(s): "Agri-vator"
try shimming the pipe up or down, working with either the saddle or by shimming the silencer/muffler up or down so that the pipe to Y junction makes a better seat.
Old 02-11-2008, 09:17 AM   #9 (permalink)
trdehmer's Avatar
Riding Since: 1984
I'll check the alignment of the pipe/Y-pipe again, but I believe its aligned pretty good right now.
A person on Arctic Chat mentioned trying to wrap aluminum foil around the donut a few times - he said others have done it and it sealed up good. Thoughts on this - can aluminum foil hold up to those high of temperatures?
Previous Sleds:
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
A Phazer
Old 02-11-2008, 01:05 PM   #10 (permalink)
kawicat's Avatar
Just an idea, but on all of our race sleds we double up the springs and never have an issue with leaking.
kawicat is offline   Reply With Quote
