ZR 800 Secondary clutch problems - HCS Snowmobile Forums
Old 02-08-2008, 12:39 PM   #1 (permalink)
flying dutchman's Avatar
Current Sled(s): '14 XF Limited 8000
Favorite Riding Area: Whiteshell/Nopoming/Spruce
15-16 Mileage: 805
14-15 Mileage: 685
13-14 Mileage: 2200
Riding Since: 1996
I have a 2001 ZR 800 and i am having trouble with the secondary clutch opening prematurely.
I notice it at slower speeds in heavier snow, it seems like the secondary opens up all the way bogging down the motor and chewing through belts.
also last night when we were riding i would crack the throttle at about 70 mph and the sled wouldnt really speed up and rpms seemed to stay constant. seem to be some vibrations and noise coming from the secondary as well
I have put all new bushings in and replaced the spring
any suggestions?
flying dutchman is offline   Reply With Quote
Old 02-08-2008, 01:35 PM   #2 (permalink)
lump800efi's Avatar
Current Sled(s): 2013 F1100 Turbo Sno-Pro Limited
Previous Sled(s): F1000 SNO PRO, ZR 900, PANTERA 800, Z370, ENTICER 250
Favorite Riding Area: mancelona
Riding Since: 1985
sound like you didnt wind the spring properly. take off belt and try pushing clutch open by hand. if it is pretty easy the spring is not wound properly. Lump
lump800efi is offline   Reply With Quote
Old 02-08-2008, 05:28 PM   #3 (permalink)
15-16 Mileage: 805
14-15 Mileage: 685
13-14 Mileage: 2200
Riding Since: 1996
How do i go about winding the spring properly? if i remeber right i did wind it up to put some tension on the spring.
If i remember right you need to wind it clockwise...?
Old 02-08-2008, 11:20 PM   #4 (permalink)
Current Sled(s): "Agri-vator"
'01s were the only 800s to use that light yellow spring. swap that out for a red-white 02-'04 zr 800-900 spring. just make sure th esping is seated in both holes, yes you need to turn the cover clockwise-preloading the spring- to get it on the studs. its very hard to do that wrong, one way will be the wrong way..loose... and if you attempt to go to far it beginns to require a Lot of force.
stronger800 is online now   Reply With Quote
Old 02-08-2008, 11:42 PM   #5 (permalink)
D&D800's Avatar
Spring could be worn out as well, they do lose tension over time.
D&D800 is offline   Reply With Quote
