6 tower / 9 tower diff ? - HCS Snowmobile Forums
Old 01-19-2008, 07:45 PM   #1 (permalink)
Current Sled(s): 2013 Assault
Previous Sled(s): 340 tnt,polaris indy 400,ZR600,F8
Favorite Riding Area: Pembina hills. Spruce woods.
I am in the market for a new clutch and I now have a 9 tower primary ( 01 zr 600 apv ) and I found a clutch for 230$ its a CAT clutch but its a 6 tower uncalibrated. I was hoping to use my weights and spring but starting to question if thats an option.
thanks.
sniper is offline   Reply With Quote
Old 01-19-2008, 07:55 PM   #2 (permalink)
mxsnow's Avatar
Favorite Riding Area: Indian River
Riding Since: 1968
If the clutch has the proper taper for your engine it will work.The spider shims might need to be changed if the updated part number for your sled does not match the clutch part number.
mxsnow is offline   Reply With Quote
Old 01-19-2008, 09:43 PM   #3 (permalink)
Sergeant HCR's Avatar
I have a 6-tower on my 01 600VEV. It was off a Bearcat 4-stroke. I had to get shims removed from it because it was throwing my rpms off. Once the shims were removed, my engagement went up 500rpm if I remember correctly.
I can't say by swapping your weights/spring to that 6-tower would be the same as the 9, but I would wager it would be.
2009 M8 HCR
Newfoundland Snowmobiling -
Sergeant HCR is offline   Reply With Quote
Old 01-20-2008, 05:10 AM   #4 (permalink)
SteveR's Avatar
ive put parts from a 9 tower into a 6 post, and never had problems. there interchangable as far as ive found
70's Olympic
87 Yamaha Bravo... bored .020 over
87 Jag 340
91 Sport 440
92 Sport 440
98 Zr 600 EFI CC LE
01 Sno Pro 440
01 Sno pro 800
01 Zr 800
.... ive turned green, and i love it!
SteveR is offline   Reply With Quote
Old 01-20-2008, 06:33 AM   #5 (permalink)
I just did a clutch swap this year. Went from a 9 tower to a 6 tower. And this is on my 01 600 also. Everything went smooth. Bought it at catdeals.com
Joey
Joe600EFI is offline   Reply With Quote
Old 01-20-2008, 09:35 AM   #6 (permalink)
MaineSled's Avatar
Current Sled(s): "14" Freeride/"09" Renegade 600 BC
Previous Sled(s): Too many to list
Favorite Riding Area: Franklin County, ME.
Riding Since: 1973
just did mine last week, all parts interchangeable between two as far as springs and weights. 6 is a bit beefier has wider rollers and better bushings its an upgrade. should come with new pins and shims. get right size 30 or 33mm. after checking online-call, I find you sometimes get a better deal,cat stuff off ebay I called endded up paying 229.95 delivered saved 10.00
2014 Freeride....let it snow now!
MaineSled is offline   Reply With Quote
Old 01-20-2008, 05:04 PM   #7 (permalink)
Current Sled(s): '15 zr5000
Previous Sled(s): ext 600,cougars,fossils T660, zl800
Favorite Riding Area: 665
16-17 Mileage: 1926
15-16 Mileage: 2265
14-15 Mileage: 1430
13-14 Mileage: 1842
Riding Since: 1978
I just put a 6 tower on a '01 zl500 had to swap the starter ring gear, weights and spring are interchangeable
the 6 is a direct replacement as was stated earlier. I picked one up at r.v. sports 229 plus shipping.
make sure weight bushings are ok before reusing them. also for 18 put a new spring in it the old ones
probably getting weak.
thefoolsbro is offline   Reply With Quote
Old 01-20-2008, 10:27 PM   #8 (permalink)
Thanks for the info , It nice not running into problems later after you have the clutch on the bench. I found this clutch at catdeals as well. Be for xmas it was 200 $ just a while back it was 279$ NOW ITS 229$ Yeah might not be a bad idea to change the spring as well. I will run it by the finance commity. pray for more snow.
Old 01-20-2008, 10:56 PM   #9 (permalink)
mnstang's Avatar
Current Sled(s): SnoPro 500, z1 turbo, zr900
Previous Sled(s): all cats
Favorite Riding Area: Northern MN
i would definitely do it, those 9 tower clutches always crack, and can fly apart (dangerous!)
mnstang is offline   Reply With Quote
Old 01-23-2009, 12:15 AM   #10 (permalink)
I can't say by swapping your weights/spring to that 6-tower would be the same as the 9, but I would wager it would be.[/b]
Are you talking the shims behind the spider, that afects the side clearance of the belt?
aczr6 is offline   Reply With Quote
