Voltage regulator/rectifier - HCS Snowmobile Forums
Old 12-11-2007, 11:45 AM   #1 (permalink)
apvzr8's Avatar
Current Sled(s): None
Previous Sled(s): 10 F8 2010 F8 SP/2010 XP MXZ 600/2002 ZR800/various others
Favorite Riding Area: Jackman/Rockwood/County
15-16 Mileage: Done
14-15 Mileage: 200
13-14 Mileage: 1400
Riding Since: 1972
I know this has been discussed in detail (just spent hours sorting thru it...) but I have a question I hope someone can answer.
I need 12Vdc for a small electric pump I plan to install on my 2002 ZR8. My present voltage regulator is part #0630-142 2-wire. Is there any reason I can't use the electric start version from a Z570ESR part #0630-143 3-wire? I assume this is a regulator/rectifier combo and the 3rd wire has 12VDC for charging the batteries. I realize I may have to do some spicing to make my 2 prong plug work with the 3 prong plug of the regulator. This would be cleaner than adding a seperate rectifier.
Thanks in advance for any info.
APVZR8
2010 F8 HO Sno Pro stock motor, 65/55 gears, 14" HS, Plowman mount, torsional setup, X-series STM's, 127 MPH at 8270 GPS verified
apvzr8 is offline   Reply With Quote
Old 12-11-2007, 04:02 PM   #2 (permalink)
apvzr8's Avatar
15-16 Mileage: Done
14-15 Mileage: 200
13-14 Mileage: 1400
Riding Since: 1972
Just founded that the 3rd wire on the above 3 wire regulator is DC but half wave, need full wave. Guess it's back to a seperate rectifier.
I know Polaris makes one but I don't want the plug. I believe the rectifier is actually built into the plug.
I've also read parts to make your own can be brought at Radio Shack. Are there any instructions anywhere on whats needed and how to make? I'm a high voltage engineer PE (345000 volt). I don't usually mess with the low voltage stuff but if anyone can point me in the right direction, I think I can put one together.
Also, any other options are welcomed.
Thanks.
Old 12-11-2007, 04:57 PM   #3 (permalink)
trdehmer's Avatar
Current Sled(s): 2016 Axys SB 800 ProS & 2015 Axys SB 800 60th
Riding Since: 1984
I bought the below a couple of years ago to run my GPS. However the website is dead?? Need a pump to spray Dawn soap on the hyfax?
http://sales.shaftek.com/snowpower.htm
Info@shaftek.com
The Snow Power unit is a product designed for snowmobiles that do not have battery's installed. This unit will convert the electrical power from your sled in to useful electricity that can be used to power almost any 12 volt accessory The Shaf Tech Snow Power unit will provide up to *5 amps of power that provides a steady 12 volt DC source that is suitiable for even the most sensitive pieces of equipment. Snow Power and the Sno-glow driver can be ordered to be built into one enclosure.
Note: The Snow power unit is a separate product that is NOT required to operate the Sno-glow system
Snow power (5 amp) $39.95
Previous Sleds:
2012 F1100 Turbo 50th
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
1990 Polaris 340 Sport
1984 Polaris 480 Trail
A Phazer
1969 Massey Ferg Ski Whiz
trdehmer is offline   Reply With Quote
Old 12-11-2007, 08:09 PM   #4 (permalink)
Thanks.[/b]
Take a look at this link or google full wave rectifier. http://www.wam.umd.edu/~toh/ElectroSim/FullWave.html
The diodes convert the AC to DC, the capacitor smooths out the ripples for smooth DC power. You won't need a transformer unless you are trying to change the voltage.
I was born at night, but not last night.
Never argue with an idiot. They drag you down to their level, then beat you with experience.
jeffzr600 is offline   Reply With Quote
Old 12-12-2007, 07:30 AM   #5 (permalink)
apvzr8's Avatar
15-16 Mileage: Done
14-15 Mileage: 200
13-14 Mileage: 1400
Riding Since: 1972
[quote]
Something like that...
The Snow Power would be perfect but can't get to the website. There is another regulator/rectifier and condensor that puts out 12VDC on the APV sleds. But at $205 for the APV regulator, I think I'll stay away from it.
Are there any other complete rectifiers available or do I need to make one?
APVZR8
Old 12-12-2007, 08:07 AM   #6 (permalink)
Jim85IROC's Avatar
If you don't mind doing a little bit of soldering, you can make your own rectifier for about $5. Radio shack sells a full wave rectifier chip for about $3.50. Then you just need a capacitor, a few pieces of wire, and if you want to, a small project box to put it into. Doing a google search for "bridge rectifier" will give you the hookup information, but it's extremely easy. The rectifier chip has 4 pins... 2 inputs and 2 outputs. You put the a/c to the input, and dc comes off the output. You solder the capacitor across the output and you're all done.
If you think education is difficult, try being stupid.
Jim85IROC is offline   Reply With Quote
Old 12-12-2007, 08:30 AM   #7 (permalink)
Scott S's Avatar
Current Sled(s): 2003 Arctic Cat ZR9, 2012 F1100 SnoPro
Favorite Riding Area: Ontario - anywhere it snows!
Riding Since: 1975
If you don't mind doing a little bit of soldering, you can make your own rectifier for about $5. Radio shack sells a full wave rectifier chip for about $3.50. Then you just need a capacitor, a few pieces of wire, and if you want to, a small project box to put it into. Doing a google search for "bridge rectifier" will give you the hookup information, but it's extremely easy. The rectifier chip has 4 pins... 2 inputs and 2 outputs. You put the a/c to the input, and dc comes off the output. You solder the capacitor across the output and you're all done.[/b]
I made mine and used the attached instructions from the web. I also went to an electronics store to get my parts as Radio Shack only ahd bits and pieces in stock.
I attached my actual parts list also for reference.
It is a easy build and mine still works like a charm running phone and GPS.
I have a hard connection to my Autometer temp gauge as well as a 12V socket.
Lead by example, it all begins with you!
Have a great day!
Scott
Scott S is offline   Reply With Quote
Old 12-12-2007, 09:15 AM   #8 (permalink)
apvzr8's Avatar
15-16 Mileage: Done
14-15 Mileage: 200
13-14 Mileage: 1400
Riding Since: 1972
Good information guys. I think I can put one together but I don't think the 1A rectifier will handle the load of a small DC motor. It appears to be geared more for electronics.
However, I noticed Radio Shack has a 25A 50V rectifier which is larger than I need but would work for my application and I would definitely fused the input side to protect the stator. I would like to put a capacitor across the output for cleaner voltage. But I'm not sure how to calculate the size and I don't want to go dig out my college books... Can't anyone give me a quick lesson?
Thanks.
