| ZR/ZL forum This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#11 (permalink) |
i got a zr 700 that i just currently put a set of ported cylinders/ shaved heads, twin psi race pipes and a set of 46.5mm carbs..when i finally got her together and fired last night up it seemed to be running a little bit in one cylinder at idle but when giving her a god bit of throttle when she was tied up in the garage it seemed to be fine...let her idle back down and it seemed to be back on one cylinder again until i gave it a few shots of throttle to get her engauging again than it was fine...did this 4-5 times and it did it every time...one cylinder at idle than get the track moving a little and revs up to around 4-5-6000rpm's and it was working fine as kind....and it is only one cylinder doing this, one plug is dry and the other is soaked?...what should my air screws be set at?.any thoughts on this would be great...and it was idling at around 25-2600rpm's with my idle screws out as far as they could go
zr 700 |
| Sponsored Links | |||
Advertisement | |||
#12 (permalink) | |
Super Moderator
Current Sled(s): 13 F1100T LXR, 07 F6, 72 Cheetah 440
Favorite Riding Area: far away from CT people
Riding Since: 1979
Illegal immigrant=against the law, time to start treating it that way! |
#13 (permalink) | |
zr 700 |
#14 (permalink) | |
Current Sled(s): 06 F7R
Previous Sled(s): 03 ZR900, 05 F7R
Favorite Riding Area: fundy park
Riding Since: 6
This ones stock!!!! 95 Eclipse runs 10.55 @ 135 , 1.6 60ft. .07 off the quickest import in maritimes :grinning: |
#15 (permalink) | |
Super Moderator
Riding Since: 1979
#16 (permalink) |
Current Sled(s): 2003 Arctic Cat ZR9, 2012 F1100 SnoPro
Favorite Riding Area: Ontario - anywhere it snows!
Riding Since: 1975
I'd verify the carbs settings. If they are off I'd go stock setup to start.
Stock 03, 900 Air Screw - 2 turns out Fuel - 1 1/2 turns out The air screw can be tweaked back to 1 3/4 out to help a bit with the idle hang. The air screw is very sensitive so try a bit at a time. It is the small screw.
Lead by example, it all begins with you! Have a great day! Scott |
#17 (permalink) |
Current Sled(s): 2012 F1100T Retro & 2003 F7
Riding Since: 1984
Turning the air screw in seemed to help with the idle. However, it still backfired on a ride yesterday. Same situation for the most part, trail rode at normal speeds and came to a stop and shut it down. Started it back up and it backfired.
Is this a sign its running to rich?
Previous Sleds: 2010 Z1 Turbo LXR 2002.5 ZR900 1999 XC 700 SP 1994 XLT SP 1990 Polaris 500 1990 Polaris 340 Sport 1984 Polaris 480 Trail A Phazer 1969 Massey Ferg Ski Whiz |
#18 (permalink) |
Current Sled(s): '11 800 Ltd / '07 F6 sp
Previous Sled(s): '08 F1000 sp / '07 F1000 sp / '02 ZR800-900
Favorite Riding Area: A snow covered one.
10-11 Mileage: 4000ish
Riding Since: 1861
Most common to backfire on start up if the RPM is high when shut off...............what is your base / hot idle speed?
#19 (permalink) |
Riding Since: 1984
After the sled is warmed up good and riding it, it will idle at about 1500 RPM (but it takes a short time to drop to it, might be at 3000 for a short period of time then will drop back to 1500). Right when I start it first thing for the day it will be at 1500 or so and stay there.
#20 (permalink) |
Riding Since: 1861
I'd turn the air screw back out and reset the idle speed to about where it is now...............Oh, shelf in or out? Shelf out makes em way more prone to hanging.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
