| ZR/ZL forum This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
Current Sled(s): F-1000
Previous Sled(s): 77 ElTigre
Favorite Riding Area: Perkin's Clearing
11-12 Mileage: not enough
Riding Since: 1972
Remove the 4 cap screws on the covers, then the torx screws (2 ea) underneath.
#4 (permalink) | ||
Current Sled(s): 09 M8 SP, 96 XCR 440
Favorite Riding Area: Mountains
to get the cable seperated form the valve itself, once you get the assembly off the jugs there should be a little cap screw between the spring and the valve, take that out and then it will basically just fall apart for you
2009 Arctic Cat M8 sno-pro 1996 Polaris XCR 440 1982 Polaris TXL 340 2002 Chevy 2500HD Duramax 2005 Honda TRX450R -TT 2004 Honda TRX450R -MX Quote:
#5 (permalink) |
on a 600 zr: per cylinder there are the obvious Four cover bolts. Then Three inner "retainer plate" allen or torx head bolts. Then the valves slide out, getting to your question , at this point -valves out of cylinder with cables still hooked- the retainer pin slides left to remove the right half of the valve and then slide it left to remove the other half. the pin on a 600 is just a pin. not a bolt like on a zr 8-9 or fcat.
the valves come apart and you have 5 loose pieces per cylinder to clean. |
#6 (permalink) |
Current Sled(s): 2011 MXZ800X ETEC Spring.
Previous Sled(s): 06 ZR9....MACH1..
Favorite Riding Area: WO @125 across StillwaterResv.
12-13 Mileage: 1250 +
11-12 Mileage: M.I.A.
10-11 Mileage: 98 FU knee
Riding Since: 1973
First attempt ,Service one side at a time.
Make sur u have the EXACT torx head size. They strip ezzee. Notice that the dimpled side of the gullotine is installed facing down! Cover the ex, valve port w/ a rag. Take a white shop rag or whatever and place under the cases over the pipe..lot easier to retrieve a dropped capscrew. Dont over tighten any bolt here.
__________________________________________________ __________________________________________________ ___________________________________ "I refuse to capitalize the names of people I have NO respect for." '11 MX Z- 800 - ETEC Spring >http://www.atvpt.com/2011_SKIDOO_MXZ.../Spec_MXZX.pdf If I speak, I am condemned.
If I stay silent, I am damned! |
#7 (permalink) | |
#9 (permalink) | |
If you think education is difficult, try being stupid. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
