| ZR/ZL forum This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
Current Sled(s): 800 etec coming
Previous Sled(s): 03 zr 900 08 f 1000
Favorite Riding Area: anywhere
10-11 Mileage: 2400m
Riding Since: 98
As I am rebuilding my 03 early build carb 900 after 7600 miles. I was wondering if anyone has some experiance with advancing the timing 2 degrees. The sled is stock except for some clutching ,gutted airbox,and carbon tech reeds. I need to be able to run on 87 octane. Am I asking for trouble? One person claims I can look for a increase in gas mileage and about 10 hp with no problems. Seems to good to be true. Thoughts are appreciated.
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Super Moderator
Current Sled(s): 2012 Polaris Assault
Previous Sled(s): lots of Cats
Riding Since: 1974
Your gonna have to run premium 91 octane ....also pretty sure you won't see 10 hp Gain...Maybe 1-2 hp might be more realistic :div20:
#3 (permalink) |
Current Sled(s): 2012 F1100T Retro & 2003 F7
Riding Since: 1984
Just add an 03 or 04 Mountain Cat CDI. You'll gain HP and Torque. But, you'll need to run 91 octane and larger jets.
Previous Sleds: 2010 Z1 Turbo LXR 2002.5 ZR900 1999 XC 700 SP 1994 XLT SP 1990 Polaris 500 1990 Polaris 340 Sport 1984 Polaris 480 Trail A Phazer 1969 Massey Ferg Ski Whiz |
#4 (permalink) | |
Current Sled(s): 2009 1200 GSX
Favorite Riding Area: Old Forge NY.
#5 (permalink) |
Current Sled(s): F-1000
Previous Sled(s): 77 ElTigre
Favorite Riding Area: Perkin's Clearing
11-12 Mileage: not enough
Riding Since: 1972
2 deg key is alot cheaper than a 1M CDI, if you do the key and run premium, might as well do the heads while your at it, I have a set already cut if you want them, makes alot of difference.
#6 (permalink) |
Riding Since: 98
So leave it set to stock timing. As its not the easiest thing to change while in the sled, I dont want to mess with it.The person who said it was safe is a reputable custom engine rebuilder. He advances his up to 5 degrees. Along with the other mods I see the need for premium gas. But in this case its hard to believe 2 degrees would call for premium gas. The gains he mentioned sounded good. I could not afford the porting work at this point which is what I would have gone with.
#7 (permalink) |
Riding Since: 1984
Not sure of the gain with the MC CDI, likely a bit better then the 2 degree timing key. No, you can't run the key and the MC CDI - you would burn it down. A 2 degree timing key is cheaper. But if you have to have someone install it for you it will cost $. Its easier to swap a CDI - which if you search around you can likely find a used one. Or find a 2002 or newer CDI and have it reprogrammed to a MC CDI.
#8 (permalink) |
The fact the slddog, the originator of this string, specified the requirement of running 89 octane fuel seems to rules out both the key and the hot MC CDI.
Fresh high octane fuel is just not guaranteed along the trails and in remote areas of Ontario. |
#9 (permalink) | |
or north of M (U.S.) 10
91 mm of bore..76 mm of stroke..8100 r.p.m...any ?'s |
#10 (permalink) |
Do we have to send the '02 and newer CDI to TRF or can most dealers re-map them to the '03-'04 MC spec?
My heads are cut so i'm already devoted to 93. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
