'98-'99 ZR 600 EFI Clutch Alignment Specs. - HCS Snowmobile Forums
Old 02-13-2006, 11:50 AM   #1 (permalink)
Maniac's Avatar
Looking for the clutch alignment specs for a '98 ZR 600 EFI. Putting a '99 EFI engine into a '98 EFI chassis. Need to know c-to-c, offset and deflection for the '98, not sure if it's the same as the '99 but I don't have that info either.
Thanks.
Maniac is offline   Reply With Quote
Old 02-13-2006, 12:40 PM   #2 (permalink)
C-C = 12.2"
Deflection = 1.5" (I think)
Offset = 5/8" (I think)
*** I don't have it in front of me but I know the C-C is 12.2" ***
cobber is offline   Reply With Quote
Old 02-13-2006, 01:04 PM   #3 (permalink)
Riding Since: 1861
Buy yourself a cheapie offset / c to c bar...............money well spent and very affordable from Royal Dist.
Old 02-13-2006, 01:56 PM   #4 (permalink)
arcticranger's Avatar
center to center is 12.2
but the clutches on and leave the secondary loose don't put the bolt in, run it on a stand and let the clutch float to were it want to be. then stop it and measure what the space is between the clutch and the jack shaft bearing make a spacers that distance. that is were the clutch want to be so let it be there.
arcticranger is offline   Reply With Quote
Old 02-13-2006, 07:05 PM   #5 (permalink)
Maniac's Avatar
<div align="right">
That might get you close, but I'm pretty sure that won't always put the secondary where it needs to be? Not to mention if it decides to take a trip it could be an expensive mistake. I'll stick to my scale and a straight edge
Thanks for the info guys.
Old 02-14-2006, 07:57 AM   #6 (permalink)
Just going by how we have set up all of the mod sleds. the clutches will self center to each other. If you let the secondary float on the shaft.
this is just for a while until you can make a spacer for it. then you bolt it on maybe i didn't make myself clear on that.
Old 02-14-2006, 08:55 AM   #7 (permalink)
mod600's Avatar
Current Sled(s): '14 500 Sno-Pro
Previous Sled(s): Custom 600, '97 ZR440, '93 ZR580, '81 Jag 4000, '77 Jag 3000
Agree with Arcticranger...that's how I set- mine up. I let mine float about a 1/16 or so. But run it on a stand to see where it wants to run. Never had any issues with it...
mod600 is offline   Reply With Quote
Old 02-14-2006, 09:47 PM   #8 (permalink)
Originally posted by arcticranger@Feb 14 2006, 06:57 AM
Just going by how we have set up all of the mod sleds. the clutches will self center to each other.* If you let the secondary float on the shaft.
<div align="right">
I agree as well. Thats how I did mine. :beer: :linemup:
Joe600EFI is offline   Reply With Quote
Old 02-14-2006, 10:18 PM   #9 (permalink)
kawicat's Avatar
Get a sledpro tool. Then you know its right. Just letting it float might be fine for offset alignment, but it does nothing for center to center or parellelism which is just as important as offset.
kawicat is offline   Reply With Quote
Old 02-15-2006, 09:25 AM   #10 (permalink)
mod600's Avatar
Get your center to center set and your parrallism and then let it float....You're right there's three things you need to check/set-up....
