need help with 2000 mxz 700 carbs - HCS Snowmobile Forums
ZX Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 08-30-2010, 10:54 PM   #1 (permalink)
priesman64's Avatar
Current Sled(s): 1998 Arctic Cat ZR 600
Previous Sled(s): 2003 Arctic Cat Sno Pro 440
ok so long story short my buddy has a 2000 mxz 700 with roundslide carbs and wants to switch to flatslides. he says stock 700s are 40 mm and my other buddy who parted out his 03 rev 800 x also has his flatslides still. pretty sure the 800 carbs are 40m also. now what is the difference between the two jetting wise? are they the same? i wouldnt think they are but i could be wrong.
thanks
Nick
priesman64 is offline   Reply With Quote
Old 08-31-2010, 05:55 AM   #2 (permalink)
patrioticinnovations's Avatar
Current Sled(s): 2015 AXYS Pr-S SB Ann 800, 2000 XCR 800
Previous Sled(s): 2003 XCR 1100, 98 XCR racer, 2005 Redline Revolt 800.
15-16 Mileage: 930
14-15 Mileage: 1280+
Riding Since: 1982
All carburetors work on pressure differentials. The greater the differential (suction), the more fuel flows through a given jet size. Plus, certain jets flow differently for a given size than others. Example: hex jets versus rounds. This has to do with entrance angles, length of orifice, etc.
Flatslides typically produce a stronger suction signal than roundslides. Therefore would likely use smaller jets than a roundslide on a given engine.
Also, a bigger cc engine has a stronger suction signal than a smaller one, so would probably use smaller jets as well.
Therefore, using flatslide carbs from a 800 on a 700 could result in the 700 being too lean unless rejetted. This can include needles and needle jets as well.
It pays to start rich and work your way down very slowly.
Old 09-14-2010, 11:05 PM   #3 (permalink)
Super Advanced Lummox
FreezerBurnt's Avatar
Current Sled(s): 07 Switchback 600 CFI
Previous Sled(s): XCR 600
Favorite Riding Area: NW of Sudbury
Riding Since: 76
The 700 ran better with roundslides + better on gas
FreezerBurnt is offline   Reply With Quote
Old 09-16-2010, 12:30 AM   #4 (permalink)
Member
rounds slides use MUCh lower jetting than flats...round slides are AWESOME! I run a set on my rev 2007 big bore! MORE POWER! cut 5 coils off and go play!
christ740 is offline   Reply With Quote
