Formula STX 583 - HCS Snowmobile Forums
ZX Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 12-14-2007, 05:36 PM   #1 (permalink)
Aspired's Avatar
Current Sled(s): 2003 SkiDoo MXZ-X 600 and 2011 SnoPro 600 XC
Previous Sled(s): 2003 ArcticCat Firecat F7 (maximum mods)
Favorite Riding Area: Keweenaw Peninsula
Riding Since: 1982
Runs very poor on low end - will not stay running or rev up nicely - have to work it up as it bogs bad, warm or cold - runs fine at and just before clutch engage point and up
Ok so here is what I have done :
cleaned carbs - completely - replaced main jets 350's
checked compression 100 PSI each
drained fuel and added fresh
unplugged and replugged all connectors
checked spark - good
So I got it running and ran it a bit while blurping the throttle hoping it would free up but didn't - though maybe a bit of the old bad gas still in lines so purged them and the primer as well and drained float bowls
So my options
1. re clean and check carbs - maybe there was some crap stilling in fuel tank it sucked in - in that case remove and flush tank good
2. check that the power valves are nto stuck open
3. check the reeds for chips
4. check again for air leak in boots and gaskest but look fine and not over or under tightened
5. tried adjusting idle - no change other than it stay running if you crank it way up but shouldn't have to
ANYONE - else have and ideas to check
I was also wondering which plug wire goes to which cylinder - seem to run the same no matter which is on which one - got it with wires off - assume left lead from coil goes to left cyclinder but have seen them different before - also can't think of why it runs both ways? Pick up must sense spark timing and not matte rwhich is on which on?
Someone want to educate me that would be sweet.
Aspired is offline   Reply With Quote
Old 12-15-2007, 01:41 PM   #2 (permalink)
Aspired's Avatar
Riding Since: 1982
Ok as far as the spark and which wire to which cylinder - figured that out.
It actually doesn't matter - since it sparks at both BTD and TDC. Why? Maybe to burn any unburnt fuel but can't really say exactly why they would need to do that. Actual reasoning would be nice if anyone had some just to get a little education, always looking to learn, that's why if like to fix stuff.
Now on to the rest - any tips would be great but I am sure I'll figure it out with a little tinkering.
Starting with idea one and working my way down!
Old 12-15-2007, 08:24 PM   #3 (permalink)
Super Advanced Lummox
FreezerBurnt's Avatar
Current Sled(s): 07 Switchback 600 CFI
Previous Sled(s): XCR 600
Favorite Riding Area: NW of Sudbury
Riding Since: 76
100psi???
ouch rotary valve Rotax are in the 135-145 range
my STX 583 was 140psi with 17,098km no rebuilds
5. tried adjusting idle - no change other than it stay running if you crank it way up but shouldn't have to[/b]
no reeds on a RV engine
engage at 3500 or so top rpm 7800
Fuel pump diaphram ripped? or dirty?
FreezerBurnt is offline   Reply With Quote
Old 12-17-2007, 02:09 PM   #4 (permalink)
Aspired's Avatar
Riding Since: 1982
100psi???
Fuel pump diaphram ripped? or dirty?[/b]
Thanks for the replay man - yea looked at it again - definetly no reeds, my bad!
So took back off the carbs, despite me having cleaned them once. The issue was the threads on the low speed were still full of stuff you couldn't see, enough so when I ran the jets back in it was pulgging the end, ran them in and out may times and got them cleaned. Check everything else again and reset to roughly stock settings.
Reassembled and fired right up
So sound like the compression is down a bit, I'll run it some then check again - hasn't been used in like 3 years so maybe the rings are slightly sticking and not seating. If he want to foot the $$$ I will gladly throwin a new topend. I know it has been poorly maintained, they never fogged it and the air box was not even screwed down when I got it, just floating aroung in there mostly off the carbs. The crab were plugged with green jell from the bad gas.
Thanks!
Old 12-17-2007, 05:43 PM   #5 (permalink)
Riding Since: 76
read your other post on jetting
I gave you the updated specs for the STX
the jets are staggered
Old 12-19-2007, 01:33 PM   #6 (permalink)
Aspired's Avatar
Riding Since: 1982
the jets are staggered[/b]
Thanks man, everything I needs and more!
Old 12-20-2007, 08:49 PM   #7 (permalink)
dxray's Avatar
Current Sled(s): A Bunch
Favorite Riding Area: Water
Should have a 330 on the mag and 320 on pto. 100psi is too low, i'd throw in some new rings.
dxray is offline   Reply With Quote
