583 big bore? - HCS Snowmobile Forums
ZX Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 04-24-2007, 05:04 AM   #1 (permalink)
Member
arcticsp2003's Avatar
I know the 670 and the 583 can swap cylinders and pistons, anyone know if the newer (00-03) 700-800 will bolt onto the 583? probably not, but I'm curious.
2000 MXZ 700 Millenium Edition 136"
2003 Arctic Cat 440 Sno Pro
2002 Arctic Cat 735 Speedwerx Mod Sno Pro
arcticsp2003 is offline   Reply With Quote
Old 04-24-2007, 09:09 AM   #2 (permalink)
blue smoke brad's Avatar
the 583 will not work with 670 cylinders the 670 has 2 more mill of bore..the 617 and the 583 are the same exept the 617 has 4 more mill of stroke..i am not to sure about the 700-800 thow
blue smoke brad is offline   Reply With Quote
Old 04-24-2007, 10:59 PM   #3 (permalink)
FreezerBurnt's Avatar
Current Sled(s): 07 Switchback 600 CFI
Previous Sled(s): XCR 600
Favorite Riding Area: NW of Sudbury
Riding Since: 76
I know the 670 and the 583 can swap cylinders and pistons, anyone know if the newer (00-03) 700-800 will bolt onto the 583? probably not, but I'm curious.[/b]
on the 583/670 comment
the 521(type536/537) and 580(type582/583) yes
the 700/800 are cylinder REED
the 583 is ROTARY VALVE
big dif
FreezerBurnt is offline   Reply With Quote
Old 04-25-2007, 01:37 AM   #4 (permalink)
Member
oops, must've been sniffing too much 2 stroke exhaust. For some reason I assumed the 670 was a bored 583, probably should have stated that differently. I feel like an idiot now. know what they say never assume anything...
i knew the 700 and 800 are reed, I was just curious as to whether through some miracle it was possible. I have an interesting summer project planned and I have a 583 rotary motor already that I was hoping to make bigger.
hmmm, back to the drawing board.
Old 04-25-2007, 01:10 PM   #5 (permalink)
Riding Since: 76
not an idiot
just a brain fart
it happens
Old 04-25-2007, 06:00 PM   #6 (permalink)
Member
A good port job will wake up the 583 and to match it replace the rotary valve with a 501. However the port job will be a lil costly I would think your best bang for buck would be regearing it for how you ride.
1997 MXZ/Summit 670
Union Bay Racing head
Ported
501 Rotary valve
136" set back suspension
MXZX seat
MBRP widening kit
FOX shocks
Flex skis
144" X 2" track
aux. rear heat exchanger
tunnel extension (street sign)
Rev snow flap
shredrider is offline   Reply With Quote
Old 04-26-2007, 08:45 AM   #7 (permalink)
I have a brand new Carbon Tech 501 rotary valve, $50 plus shipping.
Mach D is offline   Reply With Quote
Old 07-12-2007, 02:21 PM   #8 (permalink)
I have a brand new Carbon Tech 501 rotary valve, $50 plus shipping.[/b]
No longer available. SOLD!
Old 07-22-2007, 07:11 PM   #9 (permalink)
a complete swap to a 670 would be the most simple way to go bigger bore.
'06 Skidoo GTX 500ss
'83 Skidoo Blizzard 9700
'82 Skidoo Blizzard 9500
'81 Skidoo Blizzard 9500
'80 Motoski Supersonic
(2) '77 Yamaha SRX 440's
'75 Yamaha GPX 433
'77 Arctic Kitty Cat
'71 Arctic Panther 399
'71 Arctic Puma 399
snoeproe is offline   Reply With Quote
Old 01-13-2015, 03:06 PM   #10 (permalink)
Member
Default Rotary Valve & Port Templates?
I know this is an old post. I see you run a UnionBay Head on a 670. Is it a 670 or 670HO? What Compression Domes are they? How many different Rotary Valves are there for the 583/617/670? Why is the 501 better? What is the Pros and Cons of each valve?
Why is so hard for someone here to post a 583, 617, 670 Stock/Trail/Race Port Template on here?
Thanks
Rich
Armilite is offline   Reply With Quote
