'97 Classic Touring - Lights dim - HCS Snowmobile Forums
Old 01-07-2012, 10:29 PM   #1 (permalink)
meburdick's Avatar
Current Sled(s): '12 Pro-R 600
Previous Sled(s): '02 Edge X 500 / '98 Indy 440
Favorite Riding Area: On the snow, but grass works!
13-14 Mileage: 30
Riding Since: 1996
Default '97 Classic Touring - Lights dim
I have a 1997 Indy Classic Touring 500 and a 1998 Indy Classic 500. They're the same sled with the exception of the graphics and some carb settings (for some reason, Polaris used different carbs on the Classics and Classic Tourings).
Anyway...
When I start the 97, the headlight is dim and flickers. This is not the case on the 98. It will get better when the RPMs come up, but I'm still not sure that it's right.
The other thing is that I had two running lights in the rear that were blown and my speedo light is out. I'm wondering if this might be a case of bad luck (multiple lights being out at the same time), a bad regulator, a bad stator, or something else entirely.
If anyone has any input, I'd appreciate it.
Thanks!
meburdick is offline   Reply With Quote
Old 01-07-2012, 11:07 PM   #2 (permalink)
Current Sled(s): '13 Shift IQ 550
Previous Sled(s): 93/95/98 Trail, 02 SS and 00 MXZ440 (both stolen in '13)
Favorite Riding Area: Northern Wisconsin
Riding Since: 2007
90% sure it's a bad regulator. Check your stator output to be sure but more than likely a bad regulator.
Mike
Miweber929 is offline   Reply With Quote
Old 01-07-2012, 11:45 PM   #3 (permalink)
Voltage regulators tend to go on the polaris sleds. You can get an aftermarket regulator for $15-$20.
huskydave is offline   Reply With Quote
Old 01-08-2012, 06:58 AM   #4 (permalink)
meburdick's Avatar
13-14 Mileage: 30
Riding Since: 1996
Thanks, guys. I wasn't thinking Regulator until I realized that there were a few bulbs that were all blown.
What's the best way to check the Stator? How do I test it and what am I looking for? I have a good multi-meter.
Old 01-08-2012, 12:55 PM   #5 (permalink)
99_xc600's Avatar
Current Sled(s): 06 Fusion 600HO 136" and 96 Indy Lite
Previous Sled(s): 2000 XC600 SP, 2006 Polaris FST Classic 128" M10
Favorite Riding Area: Pittsburg NH
Riding Since: 1972
Voltage regulator, very common problem on Polaris sleds. Here is a simple test to confirm the regulator
Regulator is located on the right hand foot well of the sled. While sled is running, unplug the lead going to the regulator. At this point, all of the lights should come on and the flickering should stop.
DO NOT REV THE ENGINE WHILE THE REGULATOR IS UNPLUGGED OR YOU WILL BLOW OUT EVERY BULB ON THE SLED.
99_xc600 is offline   Reply With Quote
Old 01-09-2012, 10:13 AM   #6 (permalink)
meburdick's Avatar
13-14 Mileage: 30
Riding Since: 1996
Thanks. I'll have to get the sled out from it's "buried" position in the garage and check it out.
If it turns out that unplugging the regulator doesn't "do" anything... What should I check next?
FWIW: 1997 Classic Touring with about 6k miles. I've rebuild the carbs, installed all new jets, float needles / seats, gaskets, cleaned everything and dropped the needle clip one position to richen the mid-range a bit.
I also verified the carb sync, re-set the idle, and rebuilt the fuel pump. It idles around 1500-1600 and revs nice and smooth. Clutch engages right around 4200 (where it should be) and the belt is in good shape. Deflection and offset look pretty good. The track turns smoothly, but there is some surface rust on the track clips.
Rear skid needs a general lube job. Otherwise, the sled is in decent shape mechanically and all electrical items appear to function correctly (hand warmers, thumb warmers, E/S, etc).
Old 01-09-2012, 10:34 AM   #7 (permalink)
ridin' again?'s Avatar
Current Sled(s): Shopping around
Previous Sled(s): to many to list
Riding Since: 1977
If unplugging the regulator doesn't make the lights get brighter than you have a stator problem. No need to richen up a fuji 500 anywhere. They come so fat from teh factory you have nothing to worry about.
ridin' again? is offline   Reply With Quote
