95 xlt rear suspension help??? - HCS Snowmobile Forums
Old 01-19-2011, 04:30 PM   #1 (permalink)
Default 95 xlt rear suspension help???
me and my wife are looking to stiffen up the rear shock on a 95 xlt special. it has the extra 12 on it and it seems to bottom out on bumps. what can i do to stiffen it? can i put a different spring? me and my wife together weigh about 400 lbs and was wondering if anyone has any ideas? or where i can get stiffer springs. i believe they are the fox shocks on it now, purple spring
shizcol is offline   Reply With Quote
Old 01-19-2011, 04:43 PM   #2 (permalink)
gearhd6's Avatar
Current Sled(s): 1998 XLT Limited (M-10)
Previous Sled(s): 96 Indy 500, 95 XCR 600, Firecat F7 EFI
Favorite Riding Area: Western Maine
Riding Since: 1981
You've got the torsion spring adjusters set on high?
They make bigger diameter torsion springs for that.
Part # 7041406-067 for the left and 7041407-067 for the right. They're around $65 a piece though.
Current Sled
1998 Polaris XLT Limited, FAST M-10
gearhd6 is offline   Reply With Quote
Old 01-19-2011, 06:01 PM   #3 (permalink)
yeah they are on high. i tightened the spring almost all the way it is better but still bottoms out a bit. it might be better once we get more snow but id like to get better rear suspension
Old 01-19-2011, 07:16 PM   #4 (permalink)
ridin' again?'s Avatar
Current Sled(s): Shopping around
Previous Sled(s): to many to list
Riding Since: 1977
Problem with the bigger springs will be that when you are not both on it, it will bounce you all over and ride horrible. Occasional bottoming isn't that bad as long is it isn't really hard.
ridin' again? is offline   Reply With Quote
Old 01-20-2011, 11:30 AM   #5 (permalink)
yeah its not that bad, once in a while it will rub, but other then that it rides good. i have the spring set about 3/4 tightened, so i can still go down more.. would it help if i rebuilt my suispension?
Old 01-20-2011, 12:07 PM   #6 (permalink)
Current Sled(s): 09 Apex LTX 10 Vector LTX 96 500SKS
Previous Sled(s): 96Ultra 95XLTSP 72 440TNT 73 SW433 69 Panther 399
Favorite Riding Area: Central/North MN
16-17 Mileage: 360
15-16 Mileage: 468
14-15 Mileage: 784
13-14 Mileage: 2500
Riding Since: 1976
Hello All,
I am wondering if you are talking about two different springs. The rear shock on the skid has a spring over it, and apparently is purple in color, and is said to be ~3/4 preload. There are also two torsion type of springs on the skid as well. These are black in color, have long (12+) arms that ride in sliders behind an idler wheel on each side. There are adjusters on the other end of the spring on the skid near the top rear skid mount. These can also be adjusted to add more rear preload. The long arm must be removed from it's sliding point to release the tension, the block moved to the desired position and the long arm put back in the slider. If the torsion springs and the shock springs are both maxed out then the springs are shot or you need the next larger diameter torsion spring. One could also get a stiffer shock spring as well.
I hope this helps!
Good Luck!
Steve
engineman is offline   Reply With Quote
Old 01-20-2011, 03:24 PM   #7 (permalink)
the only one i mesed with was the one spring that goes over the shock. the purple one u mentioned. i didnt mess with anything else, im wondering if what ur talking about ill help. i will have to try it. thanks
Old 01-20-2011, 05:27 PM   #8 (permalink)
Riding Since: 1977
A spark plug socket will turn the adjuster blocks for the torsion springs. No need to release them from the guides.
Old 01-21-2011, 10:13 AM   #9 (permalink)
16-17 Mileage: 360
15-16 Mileage: 468
14-15 Mileage: 784
13-14 Mileage: 2500
Riding Since: 1976
Hmmm - Interesting - On my wifes 95 XLT Special the preload blocks for the torsion springs are very square. I could see possibly reducing preload without releasing the tension but I would think it would be near impossible to increase it without the tension release. IMHO I would release the tension prior to changing the block position.
Take a good look at the adjusters and try to turn then without releasing the tension. If the force on these plastic items seems to get too high then I would release the tension prior to adjusting.
Just my 2 cents.....
Steve
Old 01-21-2011, 10:37 AM   #10 (permalink)
gearhd6's Avatar
Riding Since: 1981
They're meant to be turned with preload on them from the factory with the supplied sparkplug wrench. You shouldn't use a ratchet in order to this, use something rigid like a breakerbar or a T handle so you have complete control over the block and it can't freewheel and slam into position.
Current Sled
