550 rebuild - HCS Snowmobile Forums
Old 11-30-2008, 07:57 PM   #1 (permalink)
thunderguzzler's Avatar
I am rebuilding my buddys 2000 550 SS. Burned down the pto side. The cyl. was not scored to bad and I am getting both cyl. bored out .010. What jetting changes do I need to make if any? Thanks
Owning a Thundercat is like having a totally hot girlfriend..... All of your friends want to see it, feel it and check it out..... They all want to know what it is like to ride it, but if they only knew how much time and money it takes to keep one up, they would call you a fool!.......I love it, fits perfect
thunderguzzler is offline   Reply With Quote
Old 11-30-2008, 10:38 PM   #2 (permalink)
gearhd6's Avatar
Current Sled(s): 1998 XLT Limited (M-10)
Previous Sled(s): 96 Indy 500, 95 XCR 600, Firecat F7 EFI
Favorite Riding Area: Western Maine
Riding Since: 1981
Jetting should be fine. Did you find out the cause of the burn down? Thats usually caused by a bad PTO side crank seal. It sucks air around the seal and leans that cylinder out.
Current Sled
1998 Polaris XLT Limited, FAST M-10
gearhd6 is offline   Reply With Quote
Old 12-04-2008, 06:03 PM   #3 (permalink)
Does anyone know the piston to cyl gap spec, and also the ring end gap specs?
Old 12-04-2008, 08:08 PM   #4 (permalink)
darcy32171's Avatar
Does anyone know the piston to cyl gap spec, and also the ring end gap specs?[/b]
I hope you read "Gearhd6`s post". There are two reasons why it would have burned down: Crank seal failure and carburation(froze up, settings wrong, intake boot cracked, air filter shot and sucked snow in). If I were you, I`d spend the $80 on a complete gasket set(includes crank seals) or jusy buy the crank seals and a base gasket and start at the bottom. Its cheap insurance if you don`t have a leakdown tester. Every sled I buy, no matter how good it runs, the first thing I do is pull the engine and put new crank seals in it. Gives a guy a chance to maybe catch a bearing that is on its last leg. You`d hate to spend the money on the top end and have it go, just because it was the crank seals in the first place.
"Never eat a chili cheese dog with a side of beans and expect to have dry farts out on the trail"-04nightfire
Greyhound slogan: Where might you beheaded.
darcy32171 is offline   Reply With Quote
Old 12-04-2008, 09:54 PM   #5 (permalink)
I am doing the top end and the crank seals. I like to do things right once, than wrong twice.
Old 12-05-2008, 05:39 PM   #6 (permalink)
ok, I foung ring gap, .010-.035" But can anyone help me with the piston to cyl wall clearance spec?
Old 12-07-2008, 01:23 AM   #7 (permalink)
I hope you read "Gearhd6`s post". There are two reasons why it would have burned down: Crank seal failure and carburation(froze up, settings wrong, intake boot cracked, air filter shot and sucked snow in). If I were you, I`d spend the $80 on a complete gasket set(includes crank seals) or jusy buy the crank seals and a base gasket and start at the bottom. Its cheap insurance if you don`t have a leakdown tester. Every sled I buy, no matter how good it runs, the first thing I do is pull the engine and put new crank seals in it. Gives a guy a chance to maybe catch a bearing that is on its last leg. You`d hate to spend the money on the top end and have it go, just because it was the crank seals in the first place.[/b]
Hey Darcy32171, good post....now is there a way to tell if the crank seals are bad, other than a close up visual?..I had my seals replaced last year after i melted it the first time. Seals look all good, but i don't have a leak down tester on hand to check it out. I've heard if the seals are going the idle fluctuates, but i don't know if that's true. Also heard if you give a shot of starting fluid (eether) to the seal as it runs, it should rev up if it leaks.........however, once again, i don't know if this is crazy or what. I just want to test my seals somehow.
Just Giver....
j700 is offline   Reply With Quote
Old 12-07-2008, 08:15 AM   #8 (permalink)
gearhd6's Avatar
Riding Since: 1981
Also heard if you give a shot of starting fluid (eether) to the seal as it runs, it should rev up if it leaks.........however, once again, i don't know if this is crazy or what. I just want to test my seals somehow.[/b]
Without a leakdown tester thats really the only other way to test crank seals other than actually pulling it apart and replacing them. The seal rarely ever "looks" bad, they usually just harden up or just lose their sealing qualities. Leakdown testers are the way to go, maybe you can bring it to a shop and have them do it. Do all the hard work for them, pull the carbs and Y pipe and let them just test it.
Current Sled
Old 12-09-2008, 06:11 PM   #9 (permalink)
Piston to cyl. wall clearance is .0035-.0039" for anyone that cares.
Old 12-09-2008, 08:50 PM   #10 (permalink)
gearhd6's Avatar
Riding Since: 1981
Piston to cyl. wall clearance is .0035-.0039" for anyone that cares.[/b]
Thanks for the info. Isn't there usually a "service limit" also. Meaning the MAX clearance and still be serviceable? Like .0041 or something?
Current Sled
