1996 XLT 600 TRIPLE - HCS Snowmobile Forums
Old 03-03-2008, 02:13 PM   #1 (permalink)
Thumbs up
My son was riding the sled yesterday and it stalled out.
I finally got it running and when i did it sounds like there are marbles in the crankcase and now won't idle at all. (crank seal, bearing??)
I got it going and limped it about three miles back to the house.
anyone have issues with there 600?
if so what problems have you encountered?
thanks for looking.
One way to make sure crime doesn't pay would be to let the government run it.
-Ronald Reagan U.S. President 1981-1989
Countdown until Obama leaves Office
1123 Days, 19 Hours, 42 Minutes, 56 Seconds.
bone is offline   Reply With Quote
Old 03-03-2008, 04:17 PM   #2 (permalink)
Riding Since: 1972
thanks for looking.[/b]
Sounds like the dreaded XLT PTO bearing failure. Lots of threads on it but in addition to fixing the crank you need to do a couple things to get more oil to the bearing like opening the oil port and cleaning up the champers. You can also do what I did to mine which was add 4 line oil pump. Though boy crank kit also helps which is basically an extra bearing. Cheapest thing to do would be to open up the oil passages and and turn up the oil pump as well as serious fogging in the off season. Best approach is all of these mods which basically makes it a 97xc 600
jbshocks is offline   Reply With Quote
Old 03-03-2008, 06:26 PM   #3 (permalink)
Newbie
sounds just like how my brothers arctic cat thundercat sounded chain might loosee check your chain and gears to make shure there not grinded
reedindy is offline   Reply With Quote
Old 03-03-2008, 10:44 PM   #4 (permalink)
Member
i would guess by your discription that it's the crank bearings.. If i were you i'd pull it apart to make sure, if this is the case, then I would start calling around to the local mechine shops and pricing what it would cost to have the crank pressed apart and new bearings installed.. From what I understand depending on how bad it is the motor could cost anywhere between 400 to 1200 dollars to be rebuilt... Check out my other thread it the XLT forum theres alot of helpful advice it in..
shadow17 is offline   Reply With Quote
Old 03-05-2008, 02:46 PM   #5 (permalink)
i would guess by your discription that it's the crank bearings.. If i were you i'd pull it apart to make sure, if this is the case, then I would start calling around to the local mechine shops and pricing what it would cost to have the crank pressed apart and new bearings installed.. From what I understand depending on how bad it is the motor could cost anywhere between 400 to 1200 dollars to be rebuilt... Check out my other thread it the XLT forum theres alot of helpful advice it in..[/b]
Thanks for the info.
I don't have 400-1200 to put into it, i jsut spent over 30 hours of my time and 600 clams to put a new track on it and rebuilt the entire rear suspension.
it's for sale if anyone is interested the way it sits.
Old 03-05-2008, 08:04 PM   #6 (permalink)
irv
irv's Avatar
Glad I read this, my 95 XLT SP uses oil like crazy! I was going to try and fix it but I think I will leave well enough alone now. My buddies 97 XLT SP uses about a 1/4 the oil I do.
In about 100 mile rip my oil level is just above the fill/warning line and my buddies as used about 1"s worth, maybe slightly more?............Irv
irv is offline   Reply With Quote
Old 03-05-2008, 08:52 PM   #7 (permalink)
gearhd6's Avatar
Current Sled(s): 1998 XLT Limited (M-10)
Previous Sled(s): 96 Indy 500, 95 XCR 600, Firecat F7 EFI
Favorite Riding Area: Western Maine
Riding Since: 1981
My 98 Limited uses 1 quart per 130-140 miles. So you're not TO far out. I've adjusted my pump to get that sorta oil mileage though.
Current Sled
1998 Polaris XLT Limited, FAST M-10
gearhd6 is offline   Reply With Quote
Old 03-11-2008, 11:31 PM   #8 (permalink)
In about 100 mile rip my oil level is just above the fill/warning line and my buddies as used about 1"s worth, maybe slightly more?............Irv[/b]
thats why our year xlt's last alot longer and run problem free for years....viva la 95
Eric ham is offline   Reply With Quote
Old 03-18-2008, 01:30 PM   #9 (permalink)
I determined the cheapest thing to do was purchase 5 gallons of gas and a book of matches...........
Old 03-18-2008, 01:46 PM   #10 (permalink)
gearhd6's Avatar
Riding Since: 1981
I determined the cheapest thing to do was purchase 5 gallons of gas and a book of matches...........[/b]
Haha! Yeah? It's shot? Did you tear it down?
Current Sled
