2000 Polaris rmk spark issues need help!!!! - HCS Snowmobile Forums
Switchback/SKS/RMK This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-11-2013, 09:36 AM   #1 (permalink)
Newbie
Default 2000 Polaris rmk spark issues need help!!!!
I have been having this issue with my 2000 Polaris rmk 700 all season so far and its really getting on my my nerves. It will run mint for about 5 mins then start to run on one cylinder after that. If you let it idle for a second it will come back to two cylinders and run fine for about 15 seconds then go back to one again. I don't think its the coil because its always mag side even when I switch wires and/or plugs. Carbs are spotless and fuel delivery is fine. Only thing left I think is the stator. Please tell me what you guys think it could be we just got pounded with 2 ft of snow in Maine and I'd love to be able to ride it
Sent from my Motorola Electrify using Snowmobile.com App
rmkandrew is offline   Reply With Quote
Old 02-12-2013, 10:14 PM   #2 (permalink)
Member
Current Sled(s): 99 Polaris Indy 700 SKS, 1980 Polaris Galaxy
Previous Sled(s): 06 Arctic Cat CF 600
Riding Since: 85
Hey there. Before buying a stator test the harness that runs into cdi box for continuity. If that tests good possibly your cdi is going. Just replaced my cdi on 99 700 Sks and fixed my issue. But I didn't test stator first so I'm stuck with a new stator that I can't return.
Tacomac is offline   Reply With Quote
Old 02-15-2013, 02:19 AM   #3 (permalink)
Andrew,
Order up a CDI. The stator is just a copper wire spun around a piece of bar. When the magnets in the flywheel rotate over the stator it makes energy. If one side is making enough energy to continue firing then the other side must. The spark plugs fire both at top dead center and bottom dead center. One full revolution and the spark plugs (both of them) spark a total of four times.
You say the fuel delivery system is fine? How did you check?
Not sparking, possibly stator. Sparking sometimes, go for the CDI.
Checkmarks is offline   Reply With Quote
Old 02-03-2014, 03:33 PM   #4 (permalink)
Newbie
13-14 Mileage: 80
I just had that simplar problem with my 2000 RMK 700 this weekend. Took it for a 40 mile ride to test jetting (bored it out to a 754) and near the end it would move 10-70 feet and the MAG cylinder would foul out. I also cleaned the carbs and checked the fuel pump; swapped plug wires and no change to that MAG side cylinder. What did you find out?
cedarsavage_2000 is offline   Reply With Quote
Old 02-04-2014, 04:35 AM   #5 (permalink)
ivar's Avatar
I'd take a close look at needle/seat and float pin towers, slop here may cause some weird running issues
2015 600 Adventure (int'l)
02 XC800 / 00 XCR800 - Pro-X rear skid
99 XC700SP/97 XLT SKS
RIP: 800SBA, 02 XC800, 99 SKS700
ivar is offline   Reply With Quote
Old 02-04-2014, 04:39 PM   #6 (permalink)
t-bird's Avatar
Current Sled(s): '15 Switchback Assault, '05 Fusion, '03 SKS
Previous Sled(s): Mostly Polaris
Favorite Riding Area: breaking trail
13-14 Mileage: 12
Riding Since: 1989
Float pins are a big problem area on the Keihin, if bad enough could cause the floats to jam/stick. Also, I've had a bad needle/seat cause a similar issue.
t-bird is offline   Reply With Quote
Old 02-06-2014, 04:53 PM   #7 (permalink)
Member
atvalaska's Avatar
Current Sled(s): 2005 polairs SB 151
Favorite Riding Area: Cantwell,Summit,White mtns
Riding Since: 1970
this thread is a year old ...the guys snow is ...gone ....just sayin
atvalaska is offline   Reply With Quote
Old 01-11-2015, 01:17 PM   #8 (permalink)
Newbie
13-14 Mileage: 80
The snow is back. Last year it was the float height that was incorrectly set which caused my machine to foul a plug quicker than an Alaskan hare.
Old 01-31-2015, 08:53 PM   #9 (permalink)
Newbie
More than enough snow here and 3 years later still battling the same issue. . .been going after electrical issues the whole time, definitely going to check the needle and seat and float, I wanted to change over to mikuni rack 40's anyways. Thanks for all the help.
Old 02-01-2015, 10:27 AM   #10 (permalink)
Ditch_Bangin's Avatar
I had s similar problem, check the needle, it may have snapped off and is resting in the jet, plugging the fuel supply. Also I would check your temp gauge
Ditch_Bangin is offline   Reply With Quote
