Belt to Sheave Clearance Adjustment - HCS Snowmobile Forums
Old 10-30-2005, 06:54 PM   #1 (permalink)
Current Sled(s): 2005 700 XCSP
Previous Sled(s): 1990 Polaris Indy Trail
Riding Since: 1988
I have read several posts talking about setting the belt to sheave clearance to about .010 to .020. My question is how do I do this? Different thickness washers?? Where do they go in the clutch and will I need any special tools to get at them?
I have a 99' 700xcsp - with a new belt the clearance is about .045.
andreej is offline   Reply With Quote
Old 10-30-2005, 08:01 PM   #2 (permalink)
RogerBzXCR's Avatar
Current Sled(s): 02 EXCR 00~02 XCR 800 PS 1000 XCR
Previous Sled(s): Indy 600, JDX8, Rupp Nitro
Riding Since: 1970
Yes you need to pull the clutch all apart cover spring, and the spider the spacer is under the spider, tools needed are a clutch holder, spider tool, a big poundage torq wrench I think it over 300 foot lbs
you better read up on doin this.. or find a good clutch guy to watch and
get familiar with the process..
Becareful, clutch explosions hurt!!
Originally posted by andreej@Oct 30 2005, 07:54 PM
I have read several posts talking about setting the belt to sheave clearance to about .010 to .020.* My question is how do I do this?* Different thickness washers??* Where do they go in the clutch and will I need any special tools to get at them?*
I have a 99' 700xcsp - with a new belt the clearance is about .045.*
<div align="right">
It's Like Religion Without a Bible
I am a Semi Professional Snowmobile Racer and and an Amateur Tattoo Artist!
I wana go fast!!
RogerBzXCR is offline   Reply With Quote
Old 10-30-2005, 08:44 PM   #3 (permalink)
xc-mark's Avatar
Current Sled(s): 2013 SW ASSAULT,2003 prox 7 mod
Previous Sled(s): 2004 prox 700, 2001 XC 800
Favorite Riding Area: Baker River Valley NH
15-16 Mileage: rock rides
Riding Since: 1991
you will need about 200.00 in clutch tools just to make this one adjustment...... If you think its the only time your going to set up a primary bring it to your local shop , tops it will cost you 70.00 !
Where's all the snow?
xc-mark is offline   Reply With Quote
Old 10-31-2005, 11:30 AM   #4 (permalink)
PolarisNut's Avatar
Remember to set the clearance with a brand new belt.
SOLD'06 Fusion 600 - Polaris 136", 1.25 track, 660 motor, HTG twin pipes
PolarisNut is offline   Reply With Quote
Old 10-31-2005, 01:20 PM   #5 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
Setting the belt clearence is a pretty involved job for one adjustment as others have claimed....I have seen my buddy preform this operation on a clutch or two in the past...it does require special clutch disassembly tools, and a real expensive torque wrench, and balancer after the clutch is back together. I would think if you noticed a new clutch being off that much you'd get it fixed in warranty first...otherwise if the belt clearence is fairly close...I'd live with it.
Old 10-31-2005, 01:49 PM   #6 (permalink)
balancer? don't you just line up the x's and good enough??
poster is offline   Reply With Quote
Old 10-31-2005, 03:01 PM   #7 (permalink)
PolarisNut's Avatar
When reshimming the spyder, the X on the spyder and sheave won't line up exactly. If they are off more than an inch, there is an indexing procedure to go through so you dont have to rebalance it. Like said above, its fairly involved for most people to mess with it.
Old 10-31-2005, 06:16 PM   #8 (permalink)
15-16 Mileage: Zero
Riding Since: 70 s
From what my buddy claimed....anytime you cannot get your pre-scribed index marks to exactly line up as before....you really should rebalance the clutch. You will end up with a clutch thats better balanced...better performing.... with smoother engagement. He told us this improves the operation of those older Indy..XCR...XLT 600-650 tripples big time....its not as critical in the newer ves tripples, or the Liberty twins.
Old 10-31-2005, 06:24 PM   #9 (permalink)
Riding Since: 1988
Thanks for all the replies- here's what I have concluded... It will cost me $40 to buy a puller and about $50 for the dealer to take it apart and re-shim. It is at .045 right now, would the results be worth the $90 I would need to spend to get it where it should be?
The next question would be is why isn't it set properly at the factory? It doesn't seem like something that would gradually wear out of tolerance, is it?
thanks again!
Old 10-31-2005, 06:56 PM   #10 (permalink)
xcbullet's Avatar
Current Sled(s): 01XC600
I talked to the dealer today & He said that their tolorance is up to .06in.Mine is at .03 so I dont think Im going to bother this year.
Here is a topic I started http://www.hardcoresledder.com/forums/inde...opic=100767&hl=
let it snow
xcbullet is offline   Reply With Quote
