How to remove chain case cover on a 2000 600 XC Deluxe - HCS Snowmobile Forums
Old 09-17-2013, 08:43 PM   #1 (permalink)
Newbie
Default How to remove chain case cover on a 2000 600 XC Deluxe
Hi,
I have drained the lube and got the cover loose, but there isn't enough clearance at the bottom to get the cover off.
This sled is "new" to me, so I am giving it the once over. I had to adjust the tensioner several turns, so I wanted to see if everything was good inside. The fluid appeared clean when I drained it, and the fuzz on the magnet didn't have any chunks.
Is this gonna be easy or am I looking at a big job?
I look forward to any ideas or advice.
Dave
GizmoBowler is offline   Reply With Quote
Old 09-17-2013, 10:05 PM   #2 (permalink)
meburdick's Avatar
Current Sled(s): '12 Pro-R 600
Previous Sled(s): '02 Edge X 500 / '98 Indy 440
Favorite Riding Area: On the snow, but grass works!
13-14 Mileage: 30
Riding Since: 1996
Is the clearance issue because of the coolant hoses?
Done.
meburdick is offline   Reply With Quote
Old 09-17-2013, 10:54 PM   #3 (permalink)
ridin' again?'s Avatar
Current Sled(s): Shopping around
Previous Sled(s): to many to list
Riding Since: 1977
If it has mechanical reverse, you will need to heat up the belly pan a bit and flex it out of the way. Swearing loudly and throwing tools across the garage always helps on them too.
ridin' again? is offline   Reply With Quote
Old 09-17-2013, 10:59 PM   #4 (permalink)
meburdick's Avatar
13-14 Mileage: 30
Riding Since: 1996
That sled has mechanical reverse which makes the bottom of the chaincase cover "fatter". Since it's factory-installed, the coolant lines don't have the splice in them like they would if the case was installed after-the-fact. And that means that there's little play.
There shouldn't be a need to heat the belly pan, I wouldn't think. You should be able to pull that cover by getting the coolant lines out of the way.
Done.
Old 09-18-2013, 12:56 AM   #5 (permalink)
-dw-'s Avatar
Current Sled(s): deTweaked 13 Indy, 01 600xcsp, 00 600xcsp
Previous Sled(s): 3 arcticcraps
Favorite Riding Area: from my house
Riding Since: 85
Ridin again hit it 100% plus you need a prybar and 2x4's. It gets a ton easier after a dozen or so times.
No running board coolers so no hoses in the way.
-dw- is offline   Reply With Quote
Old 09-18-2013, 03:08 AM   #6 (permalink)
D-rail's Avatar
Current Sled(s): 2016 AXYS 800 Rush Pro S
Previous Sled(s): Polaris, Ski-Doo, Yamadog, Rupp, G-Whiz, Scrap Iron, etc.
Favorite Riding Area: roller coaster stuff
16-17 Mileage: 2640
15-16 Mileage: 3339
14-15 Mileage: 2385
13-14 Mileage: 3900
Riding Since: 1973
It might help to drop the trailing arm (from the rear mount), too... gives the plastic a little more room to "flex".
When the Clintons were in the White House, Chesea complained that she had the ugliest room, so they took down the mirrors.
D-rail is offline   Reply With Quote
Old 09-18-2013, 09:07 AM   #7 (permalink)
Gta Dave's Avatar
Current Sled(s): 2013 Polaris Switchback 800, 2008 Dragon 800
Previous Sled(s): 2-2000 XCRS, 2002 XC 800, 2003 XCR, ECXR,Tour
Favorite Riding Area: Northern Maine
14-15 Mileage: 2000 plus
13-14 Mileage: 1952
Riding Since: 1988
2x4 and a little prying always works for me
"Life is not a journey to the grave with the
intention of arriving safely in a pretty and well preserved body,but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW-- What a Ride!"
Gta Dave is offline   Reply With Quote
Old 09-18-2013, 09:17 AM   #8 (permalink)
northstarrick's Avatar
no coolant hoses in the way on that. the issue is the tipped in trailing arms. remove the rear bolt to drop down like was said. alittle heat and pry with a piece of wood, like was mentioned will make this easier. its still a pita.
Old 09-18-2013, 02:41 PM   #9 (permalink)
-dw-'s Avatar
Riding Since: 85
I believe thats in the tech manual. The rear bolt on mine is froze in tight.
Old 09-18-2013, 05:00 PM   #10 (permalink)
D-rail's Avatar
16-17 Mileage: 2640
15-16 Mileage: 3339
14-15 Mileage: 2385
13-14 Mileage: 3900
Riding Since: 1973
We don't need no stinkin' tech manual...
