track tensioner bolt stuck... - HCS Snowmobile Forums
Old 01-19-2012, 03:51 PM   #1 (permalink)
polaris500custom's Avatar
Current Sled(s): 2009 Nytro xtx, Predator Camo!
Previous Sled(s): 92 500 indy class, 02 800ves edge xc, 2008 nytro rtx
Favorite Riding Area: Northern WI
15-16 Mileage: nada
14-15 Mileage: 1500
13-14 Mileage: 1025
Riding Since: 2002
Default track tensioner bolt stuck...
so i figured id make a new thread so everyone would see it and maybe someone random would chime in.
last weekend while adjusting my track tighter because of a bit of ratcheting i did one side with a wrench. did two turns. went to the other side and for the life of me i cant get the bolt to move. the nut will back off the aluminum mount but the bolt will not spin. i put a big impact on it with no luck. tried soaking it in pb blaster and still nothing. i just moved it a few months ago before winter and there wasnt an issue.
i relieved the pressure from the rear axle blocks from touching it as well and the sled rear end is now in the air.
my only thought is that the aluminum shrunk onto the steel bolt because of aluminums property to expand/contract faster than the steel bolt would??? any suggestions i could try? i tried a 3ft breaker bar but the rail just rotated with added torsion being applied.
polaris500custom is offline   Reply With Quote
Old 01-19-2012, 04:40 PM   #2 (permalink)
OldPolaris's Avatar
Current Sled(s): 2010 600 Rush , 2000 xcr 800 , 98 xc 600
Previous Sled(s): 91 xc 400 and a bunch of clunkers
Favorite Riding Area: anywheres theres snow
Riding Since: 1990
If you already tried the panther piss on it , I would go with the heat next . Use a propane torch , maybe even get a friend to help you , one fella with the torch and heat up the aluminum block and the other guy with the ratchet , start putting the heat into it and keep some strain on it . I will usually heat it up until all sign of penetrating fluid is burnt off . Steel to steel I use heat and fluid , aluminum to steel I just use heat . When you get it moving I would clean it up well and get some neverseize or something similar on there . The aluminum didn't shrink , corrosion between the aluminum and the bolt took hold , the heat will expand the aluminum to assist in breaking the bond the corrosion has formed . I'd say 2 minutes max , maybe not even that with the heat on it , if it doesn't break loose , leave cool down for 10-15 and try it again . Corroded and broken bolts are best dealt with using great patience .
OldPolaris is offline   Reply With Quote
Old 01-19-2012, 05:38 PM   #3 (permalink)
15-16 Mileage: nada
14-15 Mileage: 1500
13-14 Mileage: 1025
Riding Since: 2002
yeah i have used heat before when changing ball joints and didnt have my torch with me. just amazing what two months can all of a sudden do. ill def use no penetrating oil this time. would a impact instead of pressure help. i have had great luck with a impact and the hammering affect rather than steady pressur eon steel to steel bonds in the past on my wrx. just got home from fleet farm. guess im going back to buy antisieze. lol
Old 01-19-2012, 06:11 PM   #4 (permalink)
OldPolaris's Avatar
Riding Since: 1990
Better chance of breaking it with an impact , personally , I always use handtools when doing anything like this so I can feel it out . You may have already twisted the bolt with the power handle on it . I would also clean the threads as best you can on the axle side of the block before you try to move it and when /if you get it moving take it right out and then clean the entire bolt good .
Old 01-19-2012, 08:33 PM   #5 (permalink)
ivar's Avatar
forget the regular penetrating oils - use a "freeze shock" penetratant
Loctite Freeze & Release Penetrating Oil Loosens Rusted Bolts: Engine Builder
2015 600 Adventure (int'l)
02 XC800 / 00 XCR800 - Pro-X rear skid
99 XC700SP/97 XLT SKS
RIP: 800SBA, 02 XC800, 99 SKS700
ivar is offline   Reply With Quote
Old 01-19-2012, 08:55 PM   #6 (permalink)
nitrousxc's Avatar
Current Sled(s): 2013 600 Pro R
Previous Sled(s): 10 D6 SB, 09 8 IQ, 08 D7, 06 600 Fuse, 06 Ape-X
Favorite Riding Area: Old Forge
13-14 Mileage: 1100
Riding Since: 1988
A little heat will probably do it.
nitrousxc is offline   Reply With Quote
Old 01-19-2012, 09:03 PM   #7 (permalink)
polarisindy500's Avatar
Current Sled(s): 07 iqr 600
ive had this same thing happen to my sled. penetrating oil will do nothing. use the propane torch, and you might have to cover the rear idler wheel with aluminum foil so you dont melt it.
polarisindy500 is offline   Reply With Quote
Old 01-19-2012, 09:32 PM   #8 (permalink)
tbear0_6's Avatar
Current Sled(s): 15 800 Ski Doo TNT
Previous Sled(s): 79 TXL 340 02 700 Polaris Edge X 95 Indy 500
Favorite Riding Area: Potter County PA, UP MI
15-16 Mileage: 2200
14-15 Mileage: 1500
13-14 Mileage: 1500
Riding Since: 1979
Even without loosening the tension can you pop the rear idlers off to get them out of the way?
tbear0_6 is offline   Reply With Quote
Old 01-19-2012, 10:01 PM   #9 (permalink)
OldPolaris's Avatar
Riding Since: 1990
Remove the bolt from the axle and either knock the wheel off or drive the axle in until the wheel comes off if need be .
Old 01-19-2012, 10:23 PM   #10 (permalink)
tbear0_6's Avatar
15-16 Mileage: 2200
14-15 Mileage: 1500
13-14 Mileage: 1500
Riding Since: 1979
Oh I just had another thought for you.Once the rear wheels are off you'll have more room to heat it up. Back the lock nut off as far as you can and try to go in with the bolt if you can to get it moving. Once you get it going my dad has a great method for getting a stuck bolt out.OK once a little bit of movement is happening use a breaker bar with short back and forth motion to it pulling further the way you want it to go with each movement. The trick is know the breaking point of what your working with. Don't use the air gun you'll kill it. Hope this helps . If you need me to splain this better post up. The freeze stuff can help too. Don't kill the skid!!!
TIM
