2005 Liberty 800 Engine Noise - HCS Snowmobile Forums
Old 01-05-2012, 08:07 PM   #1 (permalink)
Drumerjb's Avatar
Current Sled(s): 14 Indy 800/ 05 800 XC/ 02 500 XC
Previous Sled(s): First sled- 72 340 Rupp Nitro,73 440 Nitro,75 440 FA Nitro
Favorite Riding Area: Any where in WI.
16-17 Mileage: 1670
15-16 Mileage: 875
14-15 Mileage: 2300
13-14 Mileage: 2100 +
Riding Since: 1968
Angry 2005 Liberty 800 Engine Noise
I just mistakenly purchased the beast & didn t notice the rattling noise until I dialed in the track & ran it 3-4 times and it reared its ugly head. Its coming from the right jug. I can actually feel the excess slop when rotating the crank back & forth. Get this,the sled has 1450 original miles. Its either rist pin or rod bearings. It seems Polaris has a problem with this motor from what i am reading. Any comments with info would be much appreciated.
Drumerjb is offline   Reply With Quote
Old 01-05-2012, 09:24 PM   #2 (permalink)
ivar's Avatar
see Very good info on 800 crank failures
2015 600 Adventure (int'l)
02 XC800 / 00 XCR800 - Pro-X rear skid
99 XC700SP/97 XLT SKS
RIP: 800SBA, 02 XC800, 99 SKS700
ivar is offline   Reply With Quote
Old 01-05-2012, 09:38 PM   #3 (permalink)
ridin' again?'s Avatar
Current Sled(s): Shopping around
Previous Sled(s): to many to list
Riding Since: 1977
Pull the cylinder and check it out before it becomes a HUGE problem.
ridin' again? is offline   Reply With Quote
Old 01-06-2012, 10:06 PM   #4 (permalink)
mwn
Current Sled(s): '05 800 XC SP M10 '65 Fox Trac 260B
Previous Sled(s): yup
Favorite Riding Area: snowy
Age: LD
You should be glad it's coming from the rt cyl rather than looking at your clutch lying on it's side with the crank snout sheared. As long as you own one now, you should follow Ivar's link and read up on them.
"Faster and Faster...Till the thrill of speed overcomes the fear of death!"
"So many trees...So little time..."
mwn is offline   Reply With Quote
Old 01-06-2012, 11:19 PM   #5 (permalink)
gen2's Avatar
Current Sled(s): 09 Dragon 800 SW, Edge/XCR 800,10 IQ LX Turbo
Previous Sled(s): 13 indy 600sp
Favorite Riding Area: U.P.
Riding Since: 1978
you could just be hearing the piston rocking back and forth in the bore . Does the piston actually stop moving when you rock the clutch back and forth in the "slop"
gen2 is offline   Reply With Quote
Old 01-07-2012, 07:15 PM   #6 (permalink)
Drumerjb's Avatar
16-17 Mileage: 1670
15-16 Mileage: 875
14-15 Mileage: 2300
Riding Since: 1968
1-7-12 Yea, tore down the top half & inspected. Can t believe the amount of piston to wall clearance, a tight .007. You would think that's to much & would make bucket noise,but both spec the same & everything looks real nice inside. I have to still mic everything to be certain
Definitely looser than the 500 I have. Polaris specs are .006 on 800 s & .0045 on 500 s. I ve got to dial the stub & go from there,I think ultimately the cranks going to get done. You can see the outer clutch wobbling,inner isn t perfect either. And I thought I got such a good deal?
Old 01-07-2012, 07:27 PM   #7 (permalink)
Drumerjb's Avatar
16-17 Mileage: 1670
15-16 Mileage: 875
14-15 Mileage: 2300
Riding Since: 1968
Yes the piston stops moving,but how much movement is acceptable? I would like to know the the bearing tolerance spec on that. If I had to estimate how much slop I would say .003 & thats enough to make the rattle noise I am hearing. Any recommendations on crank shops would be helpful. I want some one who knows whats best for situation.
Old 01-07-2012, 07:35 PM   #8 (permalink)
xc-mark's Avatar
Current Sled(s): 2013 SW ASSAULT,2003 prox 7 mod
Previous Sled(s): 2004 prox 700, 2001 XC 800
Favorite Riding Area: Baker River Valley NH
15-16 Mileage: rock rides
Riding Since: 1991
are you sure its in the motor not the primary clutch? the buttons on the spider will make a knocking knoise at idle and the exhaust valves make noise at idle. both knock and can give you a bad feeling thinking something has gone bad. Most of the the crank problems with the 800 are poor QC at the factory on case fit and bad ballance on the primary clutch that takes out the PTO bearing and cases if it no fixed early . Lack of summer fog oil can add to rusty crank or bad bearing problems .
Where's all the snow?
xc-mark is offline   Reply With Quote
Old 01-08-2012, 08:42 AM   #9 (permalink)
Current Sled(s): 01 800LE-M20/144-airwave, 06 switch 900
Previous Sled(s): 98Xc600, Indy 400-500, XLT,XCR800, Edge, Trail, xc800,,
Favorite Riding Area: NW WI
15-16 Mileage: 500
14-15 Mileage: 500
13-14 Mileage: 1000
Riding Since: 1984
I can feel the slop in mine (crank) too by turning the clutch by hand. Been like that since I bought it.
I rebuilt and balanced my own clutch and I really think it made a difference in the smoothness of the motor. Drilled about 8 holes in it. Absolutely no vibration through the handlebars while riding. Could be just a primary in need of a rebuild. As stated, they start to rattle if worn considerably.
Email me if you are interested in clutch work:
Dman142@hotmail.com
Darin
dman400 is offline   Reply With Quote
Old 01-12-2012, 11:12 PM   #10 (permalink)
Drumerjb's Avatar
16-17 Mileage: 1670
15-16 Mileage: 875
14-15 Mileage: 2300
Riding Since: 1968
Finally figured it out. Loose rod bearing. Can t believe it with 1450 for miles. Very very difficult to locate,what a huge disappointment. Had to be bad from day 1. Polaris definitely had a QC problem. Pulled motor, can t get mag off with standard steer puller I hope the right puller will work because I used a Big freaking hammer & it wouldn t move, doing all the wrong stuff to a crank but whats the diff its going for rb, unbelievable how tight. Never ran across one that tight in 35 years of wrenching.
And I thought I got such a good deal.
