how to set up edge suspension? - HCS Snowmobile Forums
Old 12-18-2010, 08:45 PM   #1 (permalink)
Default how to set up edge suspension?
Hey guys, is there a guide or anything i can get to set up my suspension. i just bought the sled and i can see someone moved the blocks in the back on me... springs have alot of pre load on them as well.. is there a general guide or book? i weigh about 230lbs
syotos is offline   Reply With Quote
Old 12-18-2010, 09:05 PM   #2 (permalink)
Current Sled(s): XCSP edge 600
Riding Since: 2008
Look on the underside of your hood
Hussler is offline   Reply With Quote
Old 12-19-2010, 03:59 AM   #3 (permalink)
edgexcsp's Avatar
Current Sled(s): 2017 Switchback Assault 800; 2003 500 Classic
Previous Sled(s): 14 SBA 800, 09 D8, 05 XCSP, 04 SuperSport, 98 XLT SP
Favorite Riding Area: Off the beaten path
16-17 Mileage: 230
15-16 Mileage: 723
14-15 Mileage: 1900
13-14 Mileage: 1941
Riding Since: 1990
Basic set up is to remove all of the preload from the front springs and the center track spring. With this done pull your back bumper up and measure to the ground, then get on the sled and bounce down on the seat, measure again. You are want your sag to be around 3" to 4". Adjust your torsion springs as needed. Closer to 3" for aggressive riding.
What blocks are you speaking of in the rear? The FRSS and RSS coupling blocks near the rear arm? Basic rule of thumb is with you on the sled and the proper sag the rear arm should be centered between the two sets of blocks.
There are some great suspension guru's on here so don't be afraid to post your results and questions. Pictures of the blocks you are talking about may help too?
SNOWMOBILING- MONEY WELL WASTED
edgexcsp is offline   Reply With Quote
Old 12-19-2010, 11:06 AM   #4 (permalink)
mn_powderhound's Avatar
Current Sled(s): 2002 XC 700
Previous Sled(s): 1996 Indy Trail
Favorite Riding Area: Wyoming
Riding Since: 1996
If you have the owner's book for it that'll give you an idea as well. I run my limiter straps in the second hole for more pressure on the skis and the rear blocks set for the most weight transfer. I'm over 200 pounds as well and ended up trading the stock torsion springs for overloads because I was bottoming way too much even after having the rear shock set up for my weight.
mn_powderhound is offline   Reply With Quote
Old 12-19-2010, 12:21 PM   #5 (permalink)
ProxBarry's Avatar
Current Sled(s): '02 prox 600 w/HTG 1200
Previous Sled(s): '00 600xc/sp Gen II '01.5 700ves edge
Favorite Riding Area: Maine & Quebec
13-14 Mileage: 450
Riding Since: 1962
I would start with pulling the shocks and make sure they are in good condition, if not start with a rebuild and then follow all of the above suggestions. Best advice is to get someone who has done it successfully to help you for the first one.
ProxBarry is offline   Reply With Quote
Old 12-19-2010, 06:06 PM   #6 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
If your running a non clicker regular pps shock in the rear...thats part of the problem why heavier guys feel a lot of bottoming or mushiness.
too slow is online now   Reply With Quote
