Splitting the Crankcase Advise - HCS Snowmobile Forums
Old 11-23-2010, 09:42 PM   #1 (permalink)
Current Sled(s): ProR Switchback
Previous Sled(s): XCSP
Favorite Riding Area: Where the snow is falling
15-16 Mileage: 10
14-15 Mileage: 500
13-14 Mileage: 1000
Riding Since: 2005
Default Splitting the Crankcase Advise
So I'm going to split the crankcase on my 2000 600 to replace the crank bearings and seals. Any advise on tear down and reassembly? I figured if I don't try I'll never learn.
acburn_22 is offline   Reply With Quote
Old 11-23-2010, 10:37 PM   #2 (permalink)
Current Sled(s): 01 800LE-M20/144-airwave, 06 switch 900
Previous Sled(s): 98Xc600, Indy 400-500, XLT,XCR800, Edge, Trail, xc800,,
Favorite Riding Area: NW WI
15-16 Mileage: 500
14-15 Mileage: 500
13-14 Mileage: 1000
Riding Since: 1984
Not too hard. Just make sure you have a clutch puller and flywheel puller. You won't be able to split the case without taking the flywheel and stator off.
D
dman400 is offline   Reply With Quote
Old 11-23-2010, 11:01 PM   #3 (permalink)
dont pry on the case halfs, unless there are pry spots (gaps, that stick out that dont effect the mating surface at all, meant for prying on) If there are none you can tap on the halves, with a rubber or plastic mallet. make sure to grease the inner lip of the seals before re assembling. Also be sure to make sure that the pins line up with the crankcase halves.
1999xcr800 is offline   Reply With Quote
Old 11-24-2010, 12:08 AM   #4 (permalink)
15-16 Mileage: 10
14-15 Mileage: 500
13-14 Mileage: 1000
Riding Since: 2005
I have the clutch puller and fly wheel puller so I should be good there. How hard are the bearings to replace. Also any good advise on putting back together.
Old 11-24-2010, 09:47 AM   #5 (permalink)
Current Sled(s): 1999 600 XC
Previous Sled(s): 1985 440 Indy Trail, 1977 John Deer 300
Favorite Riding Area: Snow
Riding Since: 2006
The outer bearings wouldn't be to bad if you have a press. You need special tools to do the center bearings as you need to press the crank apart, and orientate it when putting it back together.
The Hunter is offline   Reply With Quote
Old 11-24-2010, 05:44 PM   #6 (permalink)
Newbie
make sure to have the crank trued after replacing bearings!
171mach1 is offline   Reply With Quote
Old 11-25-2010, 01:03 PM   #7 (permalink)
15-16 Mileage: 10
14-15 Mileage: 500
13-14 Mileage: 1000
Riding Since: 2005
I'm getting there but anyone have a good easy idea to get the studs out of the top of the case? I'm decided to have the the case and jugs "decked" just smoothed out a little.
Old 11-25-2010, 07:25 PM   #8 (permalink)
If you deck the case you could/will run into a bearing crush issue. So make sure before you put it together.
05xc7 is offline   Reply With Quote
Old 11-25-2010, 07:55 PM   #9 (permalink)
alsled's Avatar
Current Sled(s): 2015 XF8000LXR
Previous Sled(s): 92,93,94,95,96,97,02,03,04,06, polaris's
Favorite Riding Area: On Snow
14-15 Mileage: 1100
Riding Since: 1991
Why?
alsled is offline   Reply With Quote
Old 11-25-2010, 08:41 PM   #10 (permalink)
15-16 Mileage: 10
14-15 Mileage: 500
13-14 Mileage: 1000
Riding Since: 2005
I changed the base gaskets last year and one was not sitting right. I had a small leak in the cylinder and I figured if I have everything opened up and the local shop has time why not get a good fit. Plus it will be free. So why not get th top of the case and the bottom of the jugs cleaned up.
