Tallest lug track - HCS Snowmobile Forums
Old 04-25-2010, 09:45 PM   #1 (permalink)
Polaris Rider's Avatar
Current Sled(s): Polaris Edge XCR 800
Previous Sled(s): 16 Pro-X 800, 12 Pro-R 800, Edge XCR 800
Favorite Riding Area: Anywhere!
What is the tallest lug track that will fit an Edge with studs? I've read that a 2" non-studded track will fit, so a 1.75" track and 2" studs should also fit I would think. Does anybody that has a 2" track or 2" studs know how close it is from the front heat exchanger?
How big of a track will fit without notching?
Polaris Rider is offline   Reply With Quote
Old 04-25-2010, 09:53 PM   #2 (permalink)
Member
QUOTE (Polaris Rider @ Apr 25 2010, 06:45 PM)
How big of a track will fit without notching?[/b]
I believe two inch I was talking to a mechanic the other day about mine. He said if I change the lug I have to change to driver make the drive lower. Lossing the top end
2002 Polaris 700VES Edge X
Fox clicker shocks
Spring Order Only
Woody Dually Carbides
1.25 Camoplast Predator Track
Red polaris composite skis with yellow loops
2 inch handlebar riser
EPI trail performance Clutch kit
Ceramic Hot Seat Manifold and Pipe
Ceramic SLP Silencer
142HP
700CC
157PSI compression
10,220 miles as of Feb 26 2010
Clutch engage@ 5,000rpms
MTUPolarisRider is offline   Reply With Quote
Old 04-26-2010, 10:50 AM   #3 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
As far as notching goes i think about 1'' lug or a bit taller is about it without the track rubbing the coolers. We once tried a 1 1/4'' track that wasn't notched on an 02 edge and it smoked the coolers till the track created its own notch.
too slow is online now   Reply With Quote
Old 04-26-2010, 12:36 PM   #4 (permalink)
darjil's Avatar
Current Sled(s): Retro Pro RMK 163"
Previous Sled(s): Dragon 800 RMK 155", XCSP700, XC600, Indy 500
QUOTE (Too Slow @ Apr 26 2010, 06:50 AM)
As far as notching goes i think about 1'' lug or a bit taller is about it without the track rubbing the coolers. We once tried a 1 1/4'' track that wasn't notched on an 02 edge and it smoked the coolers till the track created its own notch.[/b]
I have an 02 edge with a 1.25"x136" factory track on it and it is notched down to about an 1". I agree there is no room under there for a larger lugged track without notching, but you can put up to a 2" track with notching no problem. With studs in a 2" track, I have no idea? why the studs? the deep lug track is for deep snow, studs are for hard pack and ice. Are you just trying for the best of both worlds? Anyway good luck let me know if it works out.
JUST ADD SNOW!!!!!!!!!!!
darjil is offline   Reply With Quote
Old 04-26-2010, 06:25 PM   #5 (permalink)
QUOTE (darjil @ Apr 26 2010, 11:36 AM)
I have an 02 edge with a 1.25"x136" factory track on it and it is notched down to about an 1". I agree there is no room under there for a larger lugged track without notching, but you can put up to a 2" track with notching no problem. With studs in a 2" track, I have no idea? why the studs? the deep lug track is for deep snow, studs are for hard pack and ice. Are you just trying for the best of both worlds? Anyway good luck let me know if it works out.[/b]
Yes I am trying for the best of both worlds. If I can get a track that hooks up in deep and loose snow like my 1 inch track with 204 studs does on grass I would be really happy.
What's the tallest track anybody has ever studded in an Edge? My guess is a 1.5" lug shouldn't be a problem, 1.75" might be close with 2" studs and a 2" lug with studs is too tall. Any thoughts?
Old 04-26-2010, 08:07 PM   #6 (permalink)
Current Sled(s): 02 xcsp 500 M10
Previous Sled(s): 01 polaris xcsp 600, 96 xcr sp 600, 95 xlt 600
Favorite Riding Area: Vilas County
I too am putting a deep lug track on my 01 edge. My buddy put a 1.5 on his 02 xcsp with no notching and still plenty of clearance.
Someone else i heard put a 2 inch on a 01 classic without changing the drivers.
The main thing to check is the first 10-12 inches on the tunnel coolers. the rear on mine has plenty of room. I'm looking to buy a 2 inch notched track and then cut it down to 1.75 for the best of both worlds without studs.
I would think if you want studs i would go with a 1.5 crossover track and then stud it and you shouldn't have to worry about anything. My buddy got around fine with his edge in west yellowstone last january with a 1.5
If you don't care about studs then get a 1.75 or a 2 inch notched track and cut it down to a 1.75 to make it a little stiffer for trail riding.
all the sleds i refer to have or are getting a 144 tracks usa extension. not sure if you have a shorty or not and what kind of deep snow you want to be able to go through
msimo854 is offline   Reply With Quote
Old 04-27-2010, 09:36 AM   #7 (permalink)
X2freeride's Avatar
Current Sled(s): TBD
Previous Sled(s): 910 IQ IQR Pro X's RMK, XC, D7, 660 XC, XCR
Favorite Riding Area: Sandhills, River, Mountains
Riding Since: 1991
QUOTE (Polaris Rider @ Apr 26 2010, 04:25 PM)
What's the tallest track anybody has ever studded in an Edge? My guess is a 1.5" lug shouldn't be a problem, 1.75" might be close with 2" studs and a 2" lug with studs is too tall. Any thoughts?[/b]
Thats really not what your going to get though. A 2 inch track with 204 studs is going to have a wicked rotating mass. That track is heavy enough with that many studs all I can say is WOW. I dont know of anyone ever that has put 204 studs in a 2 inch track. Most I have ever seen is 96. A 2 inch lug track with studs also tends to trench in deep loose snow. Its works a lot better in hard pack setup snow. Short of hill climb sleds you really don't se people do it.
Another thing to think of is with studs 2 inch track with studs wont work at all. The studs will for sure hit the front cooler you would have to run the track guitar string tight and the first time you hit the brakes the front cooler will be done. The 1.75 might work... However you going to have to run your track pretty tight because when braking hard or anything like that your going to get those studs awfully close to the front cooler. If it were me I would go with a 1.5 track with studs, that way you can run the track where in needs to be and you can still comfortably run studs.
Sleds: 74RuppNitro440 74Panther440 92Indy650 95XLTSKS 95XLTSKS 96ULTRARMK 96XCR600 98RMK700 98XC700 00XCSP600 00XCSP136660, 02PROX700BB136 02ProX660144 05IQR700VES 04XC700136, 07D700 05IQR800VES 04PROX2800 144VAmod, 04PROXR800VES144 98Storm800 02RMK800159 00XCR800151 07RawIQ155910BB
X2freeride is offline   Reply With Quote
Old 04-28-2010, 11:42 AM   #8 (permalink)
ridin' again?'s Avatar
Current Sled(s): Shopping around
Previous Sled(s): to many to list
Riding Since: 1977
QUOTE (Too Slow @ Apr 26 2010, 08:50 AM)
1.5 fits on my 01 800 edge without notching. Clears tunnel coolers with about 1/8".
What does one need a 1.75 track with studs for? I guess I always figured if I was in snow that needed a lug that deep, studs weren't helping any. and if I needed the studs, the lugs were wayyyyyy to big for the conditions.
ridin' again? is offline   Reply With Quote
Old 04-28-2010, 03:36 PM   #9 (permalink)
catkillerppx's Avatar
Current Sled(s): Indy
Previous Sled(s): Far too many
Favorite Riding Area: Locally
15-16 Mileage: 500
14-15 Mileage: 500
13-14 Mileage: 600
Riding Since: 1999
I think the best route would be a 1.5" track with 1.6" studs (96 up the middle).
2009 Polaris IQ 600 Dragon SP: Sold
2004 Polaris Pro-X 700: Sold
2002 Ski-Doo MxzX 440: Parted Out
2005 Polaris XcSp 600: Parted Out
2003 Polaris Pro-X 600: Sold
2001 Polaris XcSp 700: Sold
2001 Polaris XcSp 600: Sold
2001 Polaris XcSp 500: Sold
2002 Polaris XcSp 500: Sold
1998 Polaris Indy 500: Sold
1993 Polaris Indy 650: Parted Out
1991 Polaris Indy 650: Parted Out
1991 Polaris Indy Sport 440: Backup Sled
catkillerppx is offline   Reply With Quote
Old 04-28-2010, 08:11 PM   #10 (permalink)
QUOTE (X2Freeride @ Apr 27 2010, 08:36 AM)
Its works a lot better in hard pack setup snow. Short of hill climb sleds you really don't se people do it.[/b]
I am planning on taking it to a few hill climbs next year, but it's also a trail sled so I have to keep it trail ride-able. When I'm not hill climbing, I'm probably off the trail with it 50% of the time anyways so that's why I wanted the big lug. As far as the studs I can almost always spin the track down to an ice base where the studs will help me.
I don't want to be worried about the heat exchanger every time I hit the brakes trail riding, so maybe 1.5" lug and studs is the way to go. How close is a 2" track from the front heat exchanger? I was thinking maybe a 1.75" backcountry and 2" studs, but if it's going to be close I don't want to risk it.
