CDI Boxes - 1998 Polaris xc 700 - Page 2 - HCS Snowmobile Forums
Old 02-10-2009, 04:37 PM   #11 (permalink)
Well it is an rmk 600, orville mention its more agressive for the rmk models? Any idea if it would work for maybe a few miles, maybe 5 miles just to test and see if it would work? Would i risk damage to anything, the cdi, or my engine? Its got SLP twin pipes on it.
westman995 is offline   Reply With Quote
Old 02-10-2009, 06:16 PM   #12 (permalink)
Banned
the 97 700 rmk or 97 700 is the box you want if it will work. hotter curve than the 98s later on and 99s.
polarisiq600 is offline   Reply With Quote
Old 02-10-2009, 06:29 PM   #13 (permalink)
ridin' again?'s Avatar
Current Sled(s): Shopping around
Previous Sled(s): to many to list
Riding Since: 1977
These should give you a bit of an idea of the difference between a couple cdi's.
[attachment=538133:98_600curve.jpg][attachment=538134:98_700curve.jpg]
ridin' again? is offline   Reply With Quote
Old 02-10-2009, 06:39 PM   #14 (permalink)
Current Sled(s): 2002 Polaris 700 Classic
Favorite Riding Area: Central Maine
16-17 Mileage: 200
15-16 Mileage: 200
14-15 Mileage: 800
I have an extra CDI from a 98xc7 if you're interested. I thought I had a bad CDI and it turned out to be the stator. Make sure it's not something stupid like you're kill switch malfunctioning or a cable coming loose from the slide in one of your carbs(both are problems I've had). As far as the cdi's go, i've heard they typically work right or don't work at all. Good luck.
markxc700 is offline   Reply With Quote
Old 02-10-2009, 07:36 PM   #15 (permalink)
the 97 700 rmk or 97 700 is the box you want if it will work. hotter curve than the 98s later on and 99s.[/b]
Why do i want another cdi other than the one specific for my 98 xc 700 engine?
[attachment=538133:98_600curve.jpg][attachment=538134:98_700curve.jpg][/b]
Dont suppose you have one for the 99 rmk 600 also? And really since i dont know anytihng about the timing curve or anything, how exactly do those two compare, and would it work?
I have an extra CDI from a 98xc7 if you're interested. I thought I had a bad CDI and it turned out to be the stator. Make sure it's not something stupid like you're kill switch malfunctioning or a cable coming loose from the slide in one of your carbs(both are problems I've had). As far as the cdi's go, i've heard they typically work right or don't work at all. Good luck.[/b]
Ill PM you. Its not the kill switch, its only doing one side of the cdi, one plug wire. Also i tried disconnecting the kill switch after it started doing the problem just to make sure, and it didnt help. Its most definitly an electrical problem..
Ive heard the same thing, but maybe i just got "lucky" and got a shitty one that is working half the time haha..
Old 02-10-2009, 08:48 PM   #16 (permalink)
Riding Since: 1977
Only other I have is 98 700RMK. They show how advanced the timing is at certain RPM's. The more advanced, the "hotter" it is. They show that the 600 is not as hot after 6000 RPM as the 700 so it would be safe to run on the 700. Just not as much power on top.
[attachment=538242:98_700RMKcurve.jpg]
Old 02-10-2009, 10:53 PM   #17 (permalink)
Ok thanks. But damn i wish i knew what it was for the 99 rmk 600, only know a buddy with that sled that i could try it off of. Now that i think of it, i think SLP might list it for their pipes.
Old 02-10-2009, 10:59 PM   #18 (permalink)
Damn nevermind they dont list it, not for that sled atleast.
Old 02-11-2009, 12:28 AM   #19 (permalink)
Current Sled(s): '11 IQ Turbo, '15 Axys 800
Previous Sled(s): '12 Pro-R 8, '08 IQ 8, '02 Pro-X
Favorite Riding Area: Where the snow is....
16-17 Mileage: 2050
15-16 Mileage: 2150
14-15 Mileage: 4050
13-14 Mileage: 6350
Riding Since: 1976
Damn nevermind they dont list it, not for that sled atleast.[/b]
Without looking it up, I think the 600 XC and RMK used the same CDI, but the 700s definitely have different timing curves. As far as damaging the motor with a different CDI, the 600 has a timing curve that is less advanced, so a 700 motor would be safe with a 600 CDI. As to the question of "Why a different module than your stock one", a CDI with a little more advance will help performance some with a stock motor/pipe. With twin pipes, retarded timing is often helpful to make more top end power. It wasn't totally uncommon for guys with twin pipes and increased compression to run 600 CDI modules because of the less aggressive timing curve (less chance of midrange detonation, more pipe heat for more RPM).
orville-x is offline   Reply With Quote
Old 02-11-2009, 12:37 AM   #20 (permalink)
Ok thanks, so i should be safe in running that 99 rmk 600 cdi box, with stator in stock position, correct? I am running twin pipes, so i may even want to go with a 600 cdi box if it ends up being the problem, or should i go with the stock one for my sled?
