04 600 xcsp carb settings HELP - HCS Snowmobile Forums
Old 02-19-2008, 07:19 PM   #1 (permalink)
Member
What are the stock settings for the main, pilot and needle and also what works best im a 1000 ft alt. Its loading up and running like !$#%$. Thanks
supercruiser is offline   Reply With Quote
Old 02-19-2008, 08:21 PM   #2 (permalink)
burr600xc's Avatar
Current Sled(s): 2017 XCR 600 - 04 600xcsp
Favorite Riding Area: Frederic-Cadillac
Here is the spec sheet off from the '05 it is the same as the '04
[attachment=433750:img006.jpg]
burr600xc is offline   Reply With Quote
Old 02-19-2008, 10:43 PM   #3 (permalink)
Luckys-04_500XC's Avatar
[quote]Here is the spec sheet off from the '05 it is the same as the '04
2004 is not the same as 2005.
Engine Model Number S2470-8070-PR8C
Alternator Output (watts) 280 w
Bore x Stroke (mm) 85 x 70
Displacement (cc) 794
Carburetor/Throttle Body 1 rack
Engine and Cooling
Carburetor Model TM40
Cooling Liquid
Cylinders 2
Ignition Timing °BTDC @ RPM 28° @ 2000 w/tps disconnecte
Ignition Type digital
Mikuni
Main Jet 460
Pilot Jet 40
Jet Needle / Clip Position J8-9DGN5-57 / 3
Needle Jet P-8
Cutaway 1.5
Fuel Screw 2.5
Idle RPM +/-200 1500
Oil Injection ves
Spark Plug Champion RN57YCC
Air Screw 1.5
Spark Plug Gap (mm / in.) .70/.025
Minimum Fuel Requirement 87 min. non-oxygenated
Pilot Air Jet N/A
Throttle Gap Under CA (mm) 2.0
It is jetted stock for 0-2000 ft, -10 to +10 degrees.
I have the complete service manual. I can remove this page at work tom. and post it for you
For more sled pictures and videos,
Luckys-04_500XC is offline   Reply With Quote
Old 02-20-2008, 06:39 AM   #4 (permalink)
burr600xc's Avatar
[quote]
The 600cc sled '04 IS THE SAME as the '05 I have both I just already had the '05 on my computer
Lucky your specs are for an 800cc sled
Old 02-20-2008, 12:10 PM   #5 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
Thought this was a 600 that your looking for the right carb specs. on....try www.partsland.com
Old 02-20-2008, 09:52 PM   #6 (permalink)
Thought this was a 600 that your looking for the right carb specs. on....try www.partsland.com[/b]
I don't know how that happenend. here it is the right one out of the Polaris manual.
