Replacing base gaskets on an XCR800 and.... - HCS Snowmobile Forums
Old 11-24-2007, 08:46 PM   #1 (permalink)
shaggy-xcr800's Avatar
Pushed out thte base gasket last year. These look like the stock ones? What's the best replacement?
Looks like a small piece went through the engine.
Sled is supposed to have 1100 miles on it(ya right) but pistons and bores look good. Has the stock jetting and all three piston tops look like this.
Replaced the carb slids last year.
Debating on the water pump seeing as its this far down. What's needed?
Any other suggestions?
2002 Polaris XCR 800
shaggy-xcr800 is offline   Reply With Quote
Old 11-24-2007, 09:35 PM   #2 (permalink)
Current Sled(s): 12 600 SB, 99xcr 800
Previous Sled(s): 09 rmk 800,edge xcr, rmks xcs
Favorite Riding Area: Northern MN &WI
for the wp you would need several gaskets and 1 seal and you can get the 2 bearings from napa pm me if you need the numbers and I will find them for you. The base gasket ranks right up there on the weird shit-o-meter.
john 800 is offline   Reply With Quote
Old 11-24-2007, 09:40 PM   #3 (permalink)
madcow's Avatar
seen lots of paper base gaskets pop out. get ahold of cometic or I can look up the number if you want. I only run aluminum, rubber coated, never blow out like paper, about the same cost but also reusable.
madcow is offline   Reply With Quote
Old 11-24-2007, 10:07 PM   #4 (permalink)
for the wp you would need several gaskets and 1 seal and you can get the 2 bearings from napa pm me if you need the numbers and I will find them for you. The base gasket ranks right up there on the weird shit-o-meter.[/b]
Just need the bearing part numbers if you have them. I have a Winderosa gasket kit on hand I could use for the pump.
seen lots of paper base gaskets pop out. get ahold of cometic or I can look up the number if you want. I only run aluminum, rubber coated, never blow out like paper, about the same cost but also reusable.[/b]
Cometic do the aluminum coated ones? I bought the Winderosa set just to get some spares on hand but they are just paper gaskets...
Old 11-25-2007, 12:12 AM   #5 (permalink)
1FASTXC's Avatar
The paper ones don't seem to hold up. Go with the rubber coated aluminum.
That's not my nitrous bottle. I'm just holding it for a friend. I swear.
Never argue with an idiot. They will only bring you down to their level and beat you with experience
1FASTXC is offline   Reply With Quote
Old 11-25-2007, 12:13 AM   #6 (permalink)
gen2's Avatar
Current Sled(s): 09 Dragon 800 SW, Edge/XCR 800,10 IQ LX Turbo
Previous Sled(s): 13 indy 600sp
Favorite Riding Area: U.P.
Riding Since: 1978
I wouldn't put a winderosa base gasket on ANYTHING ! You'll be doing it again if you do. learned my lesson on using them on XLT's and won't use them on anything more.
gen2 is offline   Reply With Quote
Old 11-25-2007, 12:54 AM   #7 (permalink)
Can one of you point me to a source for the alum gaskets? Did that torn gasket in the pic look like a Polaris part or somethng else? Thanks
Old 11-25-2007, 09:16 AM   #8 (permalink)
madcow's Avatar
just look up cometic.com and send them an email for stock gaskets but in aluminum rubber coated.
on a side note. if you look at your cylinder picture, on the top and bottom are your transfer ports, there is a bridge that makes it two passages, sharpen that to a knife edge, you will only gain a hp or two but you will have a lot cleaner idle and more crisp throttle response.
Old 11-25-2007, 11:18 AM   #9 (permalink)
1FASTXC's Avatar
Doug Flannery also keeps them in stock. That does look like the stock gasket in your pic.
Old 11-25-2007, 12:00 PM   #10 (permalink)
Blk88GT's Avatar
Current Sled(s): 2016 T3 Summit X 154
Are such base gaskets available for the small block twins?
Blk88GT is offline   Reply With Quote
