2003 edge x 600 clutching - HCS Snowmobile Forums
Old 02-27-2007, 10:31 PM   #1 (permalink)
Current Sled(s): 2016 Pro S LE 800
Previous Sled(s): 1984 centurion500,1996 xlt 600,2002 xc sp 600,fusion 600
Favorite Riding Area: north central pa.
15-16 Mileage: 245 so far
14-15 Mileage: 1100
13-14 Mileage: 1186so far
Riding Since: 1992
Unhappy
does anyone know what the stock primary spring color is,and what size weights (in grams),stock secondary spring color,and helix.
the reason i want to know is because i just purchased a2003 edge x 600 and the sled would not do over 70 mph. i took it back to the dealer and he messed with the clutching for about 3 hours.then he said that ought to do.wrong,rode it again tonight and my buddies edge x 500 walks all over it.thats sad.when he started with it i noticed it had a blue spring in it.now it has a white spring in it.the dealer said he changed the weights and spring.its still not right.it now will do 80 mph.and that is all. will the clutching off of the edge x 500 work on the 600 edge x.what i am saying stock for stock are these clutch components the exact same.thanks for any info.
swelshans is offline   Reply With Quote
Old 02-27-2007, 10:39 PM   #2 (permalink)
HSR
Administrator
HSR's Avatar
Current Sled(s): 2015 800 Pro S Switchback
Favorite Riding Area: snow
14-15 Mileage: 1000
Clutches are the same but internally components are different.Weights would be lighter in the 500.If you swapped weights you could try his clutch to see if yours is binding.I think stock weights for your 6 was 58's but most guys run 60's or 62's with almond blue.Is your present spring off-white as in almond color???What are you running for rpm at WFO?????Something majorly wrong here.Did he check the secondary out at all??
Steve
I should be a Mod on here.............
HSR is online now   Reply With Quote
Old 02-27-2007, 10:53 PM   #3 (permalink)
14-15 Mileage: 1100
Riding Since: 1992
almond is the color and as far as i know he did not check the secondary.rpms are around 9000 and that is way to high.the deal is with this guy is that i beat him down so bad on his price that now he is just putting in parts that he has in his drawer.thats why i want to know what stock clutching is,so i can throw it in his face.thanks
Old 02-27-2007, 11:43 PM   #4 (permalink)
HSR
Administrator
HSR's Avatar
14-15 Mileage: 1000
WAYY to high on the rpm.I think(off the top of my head)10-58's blue/white and an R-8 silver/blue.Try 10-60's almond/blue and silver/blue #2 hole with the r-8.
Old 02-28-2007, 01:43 AM   #5 (permalink)
Current Sled(s): 15 Indy 600sp, 05 600xcsp
Previous Sled(s): 500xc's,2002 600sp,02and06-500sp's
Favorite Riding Area: lakes and trails
16-17 Mileage: 165
15-16 Mileage: 198
14-15 Mileage: 287
13-14 Mileage: 163
Age: 5x
Riding Since: 67
I am not sure about the 03 600, but the 02 600sp comes with the blue/white-58 weights in the primary, and silver/blue-R-11 helix in the secondary.
The 02 500sp comes with the blue/white-54 weights, and the silver/blue- R-8 helix.
sb-liberty is offline   Reply With Quote
Old 02-28-2007, 02:40 AM   #6 (permalink)
Octane's Avatar
Current Sled(s): '01 Polaris 600 EDGE X
Previous Sled(s): '90 Yamaha Phazer II
Favorite Riding Area: St Germain, WI
Riding Since: 1992
Stock weights for a 600 are 10-58s. Not sure about what the stock spring is though. Just put a Polaris almond/blue spring with 10-60 weights in it and as long as the sled runs decent you should be able to eat that 500 for breakfast.
When you say, "Wisconsin", you said it all.
'07 Toyota Camry LE
'01 Polaris Indy 600 XC SP EDGE XR
Powermadd articulating bar riser with 2" riser block
red Cobra low sno-x windsheild
Pure Polaris handguards with Pure Polaris handguard mounts
Pro-X seat
almond/blue drive clutch spring with 10-60 weights
121" x 15" x .91" track with 96 studs
7,300 miles
NGK spark plugs
Citgo Sea and Snow oil
Octane is offline   Reply With Quote
Old 02-28-2007, 09:18 AM   #7 (permalink)
Current Sled(s): 2003 XCsp 700
Previous Sled(s): 2005 XCsp 700, 2001 Edge XCR 800, 2003 EdgeX 600
Favorite Riding Area: Cable, Wi.
16-17 Mileage: 596
15-16 Mileage: 740
14-15 Mileage: 835
13-14 Mileage: 745
Riding Since: 1967
almond is the color and as far as i know he did not check the secondary.rpms are around 9000 and that is way to high.the deal is with this guy is that i beat him down so bad on his price that now he is just putting in parts that he has in his drawer.thats why i want to know what stock clutching is,so i can throw it in his face.thanks[/b]
Sounds like a great way to treat someone you expect to get something fixed for you? WTF? You should start doing your own work or it will end up costing you in the long run, the dealer will get you ($$$) in the end.
NEED2SNOW (I NEED 2 SNOWmobile!)
2003 700 XCsp, 136" stretch, PERC, SLP Single
2001 Edge/XCR, 136" "Switchback" triple! Flannery Trail Ported, HTG Edge Pipes,
2005 700 XCsp, M-10 with Jack, E-Start, 2003 600 Edge "X"
need2snow is offline   Reply With Quote
Old 02-28-2007, 09:23 AM   #8 (permalink)
Blk88GT's Avatar
Current Sled(s): 2016 T3 Summit X 154
Stock:
Weights: 10-58
Primary Spring: blue/white
Helix: R11
Secondary Spring: Silver/blue
Blk88GT is offline   Reply With Quote
