dash light problems - HCS Snowmobile Forums
Old 01-15-2007, 10:18 PM   #1 (permalink)
Current Sled(s): 08 D7 and 10 D8
Previous Sled(s): 02 xcsp
Riding Since: 1979
On my 02 xcsp when I have the ignition key set for premium gas the indicator light doesn't come on in the dash. Any quick things to check before I tear it apart? Also concerned that maybe none of the warning lights work.
1shooter is offline   Reply With Quote
Old 01-15-2007, 10:27 PM   #2 (permalink)
Member
Current Sled(s): 2000 600 polaris xcsp
Previous Sled(s): 90 yamaha exciter
Favorite Riding Area: manton mi
It may just be the bulb in the dash may have blowen out . my sled did that than all of them started to go. ended up being the voltage regulator went bad but my lites keeped going on and off Tony
tmagna is offline   Reply With Quote
Old 01-16-2007, 03:16 AM   #3 (permalink)
Member
mine too kept blowing the lights. Turned out to be a bad voltage regulater
sheeeit is offline   Reply With Quote
Old 01-16-2007, 09:43 PM   #4 (permalink)
Riding Since: 1979
I haven't really looked at how hard it is to change them out. Are they easy to get at?
Old 01-16-2007, 10:14 PM   #5 (permalink)
Member
It is not that bad . Easy if you have long skiny fingers just look at where the lite would be and fell on the back side and you will find where the wire for the lite is and pull it out it is just held in with a rubber gromet if the bulb is blowen they are the same as a car side marker lite can get at any auto store Tony
Old 01-19-2007, 02:20 AM   #6 (permalink)
Member
voltage regulater is not to hard to change there is only 2 bolts holding it in It cost me $60 bucks for it
Old 01-19-2007, 04:30 PM   #7 (permalink)
Make sure you check the plug where your hood fastens to the sled. Nest to the main harness there is a single white/red wire that goes to the 3 prong plug. I pulled my hood off this summer for cleaning and forgot to reconnect that wire and had no Prem only light.
deiman8 is offline   Reply With Quote
Old 01-19-2007, 09:53 PM   #8 (permalink)
Executive Administrative Asst.
Capt.Storm's Avatar
Current Sled(s): 06 doo
Previous Sled(s): 06 apex
Favorite Riding Area: Tugg Hill
Just curious, have you blown any headlights?
Twice when i had bad regulators the headlight blew but other lights did not.
Sent from my HP Media Center Via RoadRunner...so bite me.
Capt.Storm is offline   Reply With Quote
Old 01-20-2007, 10:40 AM   #9 (permalink)
Octane's Avatar
Current Sled(s): '01 Polaris 600 EDGE X
Previous Sled(s): '90 Yamaha Phazer II
Favorite Riding Area: St Germain, WI
Riding Since: 1992
My brother had issues with blowing headlight bulbs on his '03 Pro-X 700, but that was because he used brighter bulbs than what he was supposed to use and the bulbs basically got so hot that the filiment just kinda melted. It also fried his high/low beam switch.
Since he went back to using the original wattage bulb he has had no issues.
When you say, "Wisconsin", you said it all.
'07 Toyota Camry LE
'01 Polaris Indy 600 XC SP EDGE XR
Powermadd articulating bar riser with 2" riser block
red Cobra low sno-x windsheild
Pure Polaris handguards with Pure Polaris handguard mounts
Pro-X seat
almond/blue drive clutch spring with 10-60 weights
121" x 15" x .91" track with 96 studs
7,300 miles
NGK spark plugs
Citgo Sea and Snow oil
Octane is offline   Reply With Quote
Old 01-20-2007, 12:15 PM   #10 (permalink)
redxcr440's Avatar
Current Sled(s): 03 pro x 700
Previous Sled(s): 97 xcr 440
Favorite Riding Area: st germain wi
14-15 Mileage: 250
13-14 Mileage: 550
Riding Since: 1978
Since he went back to using the original wattage bulb he has had no issues.[/b]
I never blew bulbs just the solder in the backside of the switch would get hot and then fall out. Never lost a bulb but I have had the reflectors fall out.
2003 prox 700
10-66, almond/blue
black/red, Team #719
8000 miles and still kicking
redxcr440 is offline   Reply With Quote
