03 pro-x....bent crank fix,how much?? - HCS Snowmobile Forums
Pro-X This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-21-2012, 10:02 PM   #1 (permalink)
Default 03 pro-x....bent crank fix,how much??
ok,i have checked the crank run out w/ a solid moun+mag base dial indicator,and im getting .008 at the inner large part of the crank in between the taper.and the seal..,so... i guess i might rebuild,and do the wide brg kit. so if i buy a ready to go crank,w/ the wide brg installed,what do i have to do to the crankcase?? will i need align honed? and what exactly is the machining process is needed to install the wide bearing??? how much is the machining [align hone+wide brg] going to cost??? just trying to get an idea of the repair,and if i should fix,or part out. thanks,mike
.....sleds i have today.....lol
1. 2001 thundercat esr.backup
2. 2001 thundercat..going 1107!
3. 2003 zr900 black..'ol dependable
4. 2003 zr900 snopro black..wifes..
5. 2003 zr900 green d-d twin piped+
6. 1999 zrt drag chassis roller..PARTED OUT
7. 2003 polaris 800 pro-x piped FOR SALE/trade
8. 2002 zr800 w/D&D 1010....SOLD
9. 1991 550 ext iceracer/mod
10. 1975 rupp 440 F/A
11. 1990 polaris indy 650 "stinker"
12. 2005 ski doo 600 rev
imfixinmopars is offline   Reply With Quote
Old 02-21-2012, 11:03 PM   #2 (permalink)
chimmy's Avatar
Current Sled(s): '12 Pro RMK 800, '04 ProX2 700
Previous Sled(s): Still have 95 XLT Sp, 94 XCR 440
Favorite Riding Area: Mountains, Ditchbangin'
12-13 Mileage: 92
11-12 Mileage: 400
10-11 Mileage: 1000
Riding Since: 2000
Cant help you with all your questions but last spring when I bought a reman crank for my 700, I asked about how much it would be for the wide bearing crank and they told me same price (I paid $400 for the complete remaned crank, with my core sent to them) I would have just had to send them my cases and have them machine them for the wide bearing.. Didn't ask anymore questions on the cost of that though...
IN MEMORY OF MY BROTHER JARED (4/9/91-5/31/10) RIDE ON JP!!!
chimmy is offline   Reply With Quote
Old 02-21-2012, 11:44 PM   #3 (permalink)
Before you go spending the big dollars on a new crank, wide bearing kit, etc, make sure the .008 runout you got is a true number. I had about the same number when I measured at the begining of this season before I realized I needed to do two things:
1) Mount the indicator base to the engine block itself, not the chassis. Just the forces of turning the engine over cause it to shift a few thousandths on the motor mounts, throwing off the reading. You'll need to get creative with this since a magnetic base and an Aluminum block dont really work together.
2) Polish up the PTO end with fine-grit emery cloth. I small amount of corrosion here and there will add to your runout value. Wipe clean with IPA when complete.
After I did those two things, my runout went down to .0011, well within spec. I breathed a heavy sigh of relief as I cracked a beer and smiled at my sled.
dmjarosz is offline   Reply With Quote
Old 02-22-2012, 07:48 PM   #4 (permalink)
apollonalo's Avatar
Current Sled(s): Pro xr 800 #357
Previous Sled(s): Pro xr 800 #315
Favorite Riding Area: Everywhere
12-13 Mileage: 100
10-11 Mileage: 800++
Riding Since: 1980
X2
apollonalo is offline   Reply With Quote
Old 02-22-2012, 09:56 PM   #5 (permalink)
i put the primary on the crank,with out the spring,and end face bolted on,and you can see the end of the clutch shaft wobble....its bent.
Old 02-24-2012, 06:13 PM   #6 (permalink)
apollonalo's Avatar
12-13 Mileage: 100
Riding Since: 1980
I guess if it were me I would be checking the end of the crank all cleaned up with a good dial indicator attached to the case and not the piece of alum bolted on the end of it that takes a beating. My 2 cents.
Old 02-24-2012, 08:13 PM   #7 (permalink)
i did that first.....008" out w/ a good mounting source for the dial ind.....then,for the heck of it...installed the clutch,without a face,and u can see it wobble.
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
