Trailer Tie-Down Bars, Bolt Assemblies, Vinyl End Caps, Sled Locks - HCS Snowmobile Forums
Old 09-08-2012, 11:07 AM   #1 (permalink)
Default Middle Sled Trailer Tie-Down Bars, Bolt Assemblies, Vinyl End Caps, Sled Locks
A Middle Sled Snowmobile Trailer Tie Down will securely hold your 3rd sled facing backward in the middle of your trailer, or one snowmobile loaded in the middle of your trailer . The bar is aluminum with vinyl ski protectors and end caps, and 2 stainless steel bolt assemblies . This model is for Floe, Triton, Aluma and other trailers with tie-down channels. $88. Now also available as a universal model for trailers with a recessed nut in the trailer deck. $58 for an aluminum bar with vinyl sleeves and end caps, $68 with holes drilled to your specs.
46" Aluminum bars with 12" vinyl ski protectors on each end. $48.95.
New bolt assemblies for trailers with tie-down channels, including Floe, Triton, Aluma and others, made from 100% stainless steel - $25.00.
New vinyl ski protectors for snowmobile trailer tie-down bars. 1" x 2" x 11 3/4". 50 sets available. $15 for a set of 2.
Keep your snowmobile secure on your trailer with the Snowmobile Lockdown. Place the Lockdown over the tie-down bolt and over the tie-down bar. Then drop a washer over the bolt, and tighten the nut. Secure your padlock through the chain and around the tie-down crank handle. The Lockdown is made of coated steel, with a 3/4 inch hole. The Lockdown is 2 1/8 inch wide. $15 each.
Located in the western suburbs of Minneapolis. Shipping available. Thank you. 612-719-4158
maximumpsi is offline   Reply With Quote
Old 10-15-2012, 08:13 AM   #2 (permalink)
Ttt
Old 11-19-2012, 11:15 AM   #3 (permalink)
TTT
Old 12-31-2012, 10:21 AM   #4 (permalink)
TTT
Old 02-04-2013, 04:50 PM   #5 (permalink)
The bolt assemblies fit into channels on Aluma trailers as well.
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
