| Apex / Vector / Rx1 This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
Newbie
Hello everyone,
I am crossing my fingers someone here can help me with a belt/clutch problem been having for 2 seasons now.. I have a 2003 rx-1, after about 25 km of driving i start to burn my belt. in reverse the sled doenst even move, just burns the belt, big smoke show. in forward. the sled sloowly starts to move, but at the same time the belt is smoking. Have a feeling the primary clutch isnt catching, and the secondary just spins as i give more gas and thus burning the belt. Does anyone here know how to fix this? ? i am an electrician and noo mechanic, but i am capable of fixing with instruction... please, any help is greatly appreciated especially as this is my last week to ride till next winter |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | |
Current Sled(s): 06 F7 Sno Pro EFI, 97 "Formula III 600"
Previous Sled(s): 94 Indy Lite 340/Formula STX 583
Favorite Riding Area: Rippin snowy rds an Powerlines
12-13 Mileage: 525
11-12 Mileage: 19372
10-11 Mileage: 28900
Riding Since: 10BC
Check the clutch alignment, my first thought. Do you hit you clutches:belt with emery cloth before putting it on?
00 Ram 1500 extcab 4x4. 5.9 w/ duals 69 Dodge Dart GTS340 02 CR125R F7 SP Boondocker 2.5* key D&D y&powerlite Clutched Quote:
#3 (permalink) |
Newbie
Okk, researching on checking clutch alignment now, and will look into to that.
And noo i do not wipe the clutches or belt with emery cloth before putting on,. never herd of this, i wipe the old burnt belt off the clutch yes,, but do you reccomend for the belt aswell? I will start doing this. i will test this out, will be buying another belt, hopefully last tomorrow.. keep responses comin!! thankss!! |
#4 (permalink) | |
12-13 Mileage: 525
Riding Since: 10BC
Emery cloth scuffs the belt and the clutch surface, making it grip instead of slide. Also, make sure to break in the belts, don't just slap em on, pull the cord and pin it, you'll glaze em pretty regularly if you do it like that.
But ya, like I said, sounds like the clutches aren't aligned. Good luck
#6 (permalink) |
Current Sled(s): 2000 XCR 800 turbo
Previous Sled(s): 2003 XCR 1100, 98 XCR racer, 07 Attak
Riding Since: 1982
You probably have a problem in the secondary. May be a broken or weak spring or bad buttons. Check it by removing belt and see how easily you can rotate the inner half backwards. Should take around 12 lbs to move it backwards. If too weak, or sticking, it will cause belt slip. Possibly, someone mis-assembled it at some point.
#7 (permalink) |
Newbie
ahh, this may also be the culprit! Im going to check alignment now, while belts off ill see if the second half is weak--- i know yamaha dealer took this apart apart 2 years ago when i sunk it.
Ill take apart to see if broken springs or bad button- researching noww! Thanks for replies!! keep em comin! |
#8 (permalink) | |
12-13 Mileage: 525
Riding Since: 10BC
What'd you find?
#9 (permalink) |
Newbie
alright, i just got back from the rx1, First i took the belt OFF.
took emery cloth to the belt and cleaned the clutches, and used emery cloth on them too. Checked the secondary, move the inner disk, and it moves about quarter turn, then springs back, no sticking, it was smooth, but would only move quartre turn if that. put belt back ON, in forward, seems fine, primary clutch moves and seconary moves allowing belt to fall deeper in the clutch.. in reverse, primary clutch moves fine as i give more throttle, then the secondary doesnt move, almost as if it locks up and the belt stays on top of clutch, so the more gas i give the primary speeds up, but the secondary just sits there and the belt starts to spin an smoke ![]() then sometimes! when i put back in foraward the secondary sticks again! ![]() this is complicate as i cannot find the service manual anywhere on the net to take apart secondary clutch... Could this be a bent axel??? anyways i may be going to dealer on this one eh? let me know what you think!! |
#10 (permalink) | |
Riding Since: 1982
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
