RX-1 HEAT EXCHANGER REPLACEMENT!!!! - HCS Snowmobile Forums
Apex / Vector / Rx1 This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-20-2010, 11:28 AM   #1 (permalink)
Newbie
Smile
Ok So i have a 2003 RX-1,im planning on replacing my heat exchanger due to studs pulling out of track and goin through radiator.Is this something i can do at home?I have done all previous work on sled.Do i have to pull the engine out for this?Any help from u guys would be greatly apprechiated.
I.L.V. is offline   Reply With Quote
Old 02-21-2010, 07:01 PM   #2 (permalink)
Newbie
20valves's Avatar
how did studs hit running board heat exchanger?? or optional heat exchanger @ snow flap?
20valves is offline   Reply With Quote
Old 02-21-2010, 07:36 PM   #3 (permalink)
Newbie
QUOTE (20valves @ Feb 21 2010, 07:01 PM)
how did studs hit running board heat exchanger?? or optional heat exchanger @ snow flap?[/b]
Studs were installed by previous owner and did a shitty job.It hit the one in front of the track,i guess that be the optional one.it dont look like a fun job,but its gotta get done.
Old 02-21-2010, 07:48 PM   #4 (permalink)
Member
My brother had a pick go though his exchanger in his mach z when he had it and he just got it welded. took the skid out an brought it on a trailer. if its not a real big tear you could probably go that route.
fastryder is offline   Reply With Quote
Old 02-23-2010, 07:47 AM   #5 (permalink)
Newbie
This is what i'm doing on my 08 APEX right now..
good luck trying to take it out...
It's rivetted about 100 times and the motor would need to come out..
looks like the first piece they installed...
So i took the track off and got some Aluminum Welding Rods.. going to weld it up tonight..
www.durafix.com
I'm sure any product like this should work fine...
Also it's a good time to do your Clutch Side drive and jack bearings..
95-vmax is offline   Reply With Quote
Old 02-24-2010, 07:52 PM   #6 (permalink)
Newbie
[quote]
www.durafix.com
Ok Cool i was planning on trying to do that myself,i figured the engine wouls have to come out..sucks the big one.i also planned on doing my bearings also.Thanks for your help
