HCS Snowmobile Forums
HCS Snowmobile Forums (http://www.hardcoresledder.com/forums/)
-   Apex / Vector / Rx1 (http://www.hardcoresledder.com/forums/300-apex-vector-rx1/)
-   -   What setting for track tension on APEX GT 2006 (http://www.hardcoresledder.com/forums/300-apex-vector-rx1/456384-what-setting-track-tension-apex-gt-2006-a.html)
bigshotxcr 01-16-2010 09:40 PM
Hi, I got a 2006 APEX GT and I want to know what tension I got to adjust the rear track.
I tried to search the entire forum with no success.
Or maybe if its in the owner's manual ( witch I dont have ) maybe some one as a link to one.
Thanks !
Capt.Storm 01-17-2010 03:13 AM
Thanks ![/b]
I run mine as lose as posable ...if it ratchets,I tighten it some more.
Mine hangs down maybe a inch or so.
tttario 01-17-2010 11:56 AM
2" sag with 20 lbs pull is spec. Try to run it as loose as possible before ratcheting. Save ya some hyfax.
vmaxx05stud 01-17-2010 02:28 PM
2" sag with 20 lbs pull is spec. Try to run it as loose as possible before ratcheting. Save ya some hyfax.[/b]
i didn't read that it was 2"?? per manual you use a scale and put 22 lb ft of pulling force on the track and should have 30 to 35 mm of space between the slider and track. however i would loosen it as much as you can w/out ratching as it will wear hyfax quicker when it's at the manuals recommended setting. imo
tttario 01-23-2010 12:50 PM
i didn't read that it was 2"?? per manual you use a scale and put 22 lb ft of pulling force on the track and should have 30 to 35 mm of space between the slider and track. however i would loosen it as much as you can w/out ratching as it will wear hyfax quicker when it's at the manuals recommended setting. imo[/b]
Sorry 2" @ 20lbs is my spec. Running 1 3/8" (35mm) @ 22lbs will smoke your sliders and kill top end. Been there done that.
Cheers.
quebec#1 01-23-2010 02:01 PM
Change all you idler wheels to polaris or doo's ones and you can run the track tighter and only change you slider's for the first time at 7000 miles like i did !
duste 01-23-2010 07:53 PM
The track tension as well as idle speed , spark plug type and a few other specs are on a sticker on the left side of the delta box frame over right over the belt cover, I read it today but I forget the spec.
Capt.Storm 01-23-2010 10:01 PM
Change all you idler wheels to polaris or doo's ones and you can run the track tighter and only change you slider's for the first time at 7000 miles like i did ![/b]
Some have good luck doing that..otheres not so lucky...puts more stress on the rails.
